ProScan: Programming options in ProScan
Skyd
Northern Grafton County, New Hampshire
Hi all - so I've been doing a little bit of programming on my new Uniden BCD996P2 using Freescan. So far it's worked really well for my needs for the time being.
However - I can't find a way to set the Tone to SEARCH in freescan. I can do it manually in the scanner, but that's kind of a pain and the point of the software is to not have to muck around on the scanner for hours.
I'm wondering if anyone knows if ProScan does this? I know there's a free trial and I'll probably download that soon but I'd like to know ahead of time, as it's a limited trial.
Also - Can you record hits with Proscan? I haven't even looked to see if you can or can't with Freescan but figured I'd ask while I'm here.
ka3aaa
middletown, pa.
yes that can be done, download from one scanner and save file, change scanner to new target scanner, swap out scanner to new target scanner, open the saved file and upload to target scanner.
i may have missed a step or some thing minor but you get the idea. its not that hard.
ProScan
Software Provider
Ontario, Calif.
Just wondering if you can Clone an SDS100 to BCD325P2?
Also BCD396T to SDS100?
ProScan set to a DMA type of scanner can import the FL from a HP type of scanner.
ProScan set to a HP type of scanner can import the database from a DMA type.
HP = SDSx00/BCDx36HP scanners
FL = Favorites Lists
DMA = Dynamic Memory Architecture
hunterca
SDS150
Ottawa
I guess that means the opposite direction HP to DMA scanner can be done as well?
I really like how it prints out. There is room to write in new TGIDs. One thing I do not see on the printout is the CC and LCNs.
