Programming Talkgroups Pro-92
scannerhead3
Connecticut
can anyone explain to me how to program talkgroups into the pro-92. Especially EDACS and LTR types. I looked at the manual but hopefully someone can explain it a little better. THANKS
Eng74
Kern County, CA
First get Win92 from Don Starr, it is free and you use the same cable (RS# 20-289) for 92/2067/93/2053/95/96/2096. Then just plug in the nubers into the right box and you will be set.
basstuba
i tryed to download it opens with windows picture and fax viewer but no info what am i doing wrong what program open this ? :?
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
scannerhead3 said:
i downloaded the program ---but where do i plug the cable into my computer And can i use the cable that came with my pro 92
It depends on what cable you have.
If it has a male mono plug on each end, then it is a cloning cable and used only for cloning one scanner to another.
If it has a male mono plug on one end and a 9 pin serial plug on the other, then it might work providing it is this Radio Shack or Scanners Cables.com or BlackBag or GRE. This Radio Shack cable is not for this scanner.
scannerhead3
Connecticut
i got the cord and everything works so thats good and i went and put in some freqs that are in LTR mode (ex. 0-05-048) but when i hit scan the scanner doesn't think there are any freqs in that bank. ANY IDEAS???
fmon
Eclipse, Virginia
Freqs are in this format: xxx.xxxx.
Make sure they are on the left side of Win92 under freqs.
x-xx-xxx are talkgroup ID format.
Make sure they are on the right side of Win92 under Talkgroups
fmon
Eclipse, Virginia
scanner doesn't recognize them because it doesn't scan that bank
You've said this twice, if not scanning...what is it doing? Did you check LTR for each of the freqs and the bank as well in Win92?
