Programming TK-361
M0YDC
South UK
I have some Kenwood TK-361 radios I would like to program with different frequencies but not able to connect with the lead I have. It is for Kenwood radios but for models like the TH-F7 so I suspect it is wrong.
I am using a laptop with windows 7 pro and using DOSbox 0.74 which opens the KPG34D software OK and I assigned the right port.
Assuming my cable is wrong, what cable do I need (bearing in mind I am in the UK) or is there any diagrams around so I can make one? This laptop I use only has USB ports, is that an issue also?
Thanks.
cmdrwill
So Cali
I think you will need a Real DOS computer setup, with a real serial port.
M0YDC
South UK
I did wonder about this so may look into getting one for future use. I am still wondering about the lead but if it is USB the will be no good on a DOS machine with serial port only.
I want to be able to keep the older transceivers going by re-programming them on amateur frequencies so will try and find a suitable older PC and get or make the correct leads. Finding the information required is the harder bit.
