Programming TV channels in Uniden 396
pjsuarez
When I try to establish a system for TV audio, I select "Conventional" as the system type. I choose Edit Group, New Group. I then choose Edit Channel and manually enter channel frequencies. When I get above Channel 13, though, I get "Out of Band". How do I set up a system/group to include frequencies starting at 475.75? Thanks.
loumaag
Silent Key - Aug 2014
Katy, TX
I would try again, because the radio has no problem setting up those frequencies.
pjsuarez
Still a no-go
I deleted the entire TV group and system and tried again, but still am getting "Out of Range" when I try to enter those higher frequencies. I am stumped. Any other suggestions would be greatly appreciated. Thanks.
pjsuarez
Problem solved -- but not happy
The scanner can't pick up anything between 512MHz and 764MHz. Why would Uniden do this? @#$%
UPMan
In Memoriam
Arlington, TX
Simultaneous posting. Same message. Typing here to make message long enough for RR to accept.
loumaag
Katy, TX
As plainly stated in the specifications of the radio.
But you were complaining about 475.7500 and it has no problem there.
