Programming
bodene
Ms
I currently have a GRE PSR-800 scanner. Can someone tell me how do I send info to the scanner after I have imported it to scanlists using ez-scan software? Step by step instructions will be greatly appreciated. Thanks in advance.
Blackswan73
Central Indiana
Two ways. You can remove the card from the scanner and connect it to your computer with a card reader. Then write your configuration to the card (fastest). Or connect your scanner to your computer with the USB cable provided, and with the scanner turned off , write directly to the scanner with the card installed.(slower). Either way be sure to make a backup and save to a stick, another card, or a folder on your computer
