ProScan: ProScan can see scanner, but won't connect and operator.
Rabbitiswise
S.E. Michigan
For some reason ProScan is seeing my scanner, but will not connect to it. Was working fine when I went to bed, but the following morning I'm dealing with this. I've looked everywhere in my internet setting, network setting and can not find what was changed. Any and all help will be appriecated.
belvdr
Have Nord off, and windows turned off. Thats what is driving me nuts.
Unless you want to remove software as a test, you’re left with Wireshark to see if you can see packets pass between the systems.
ProScan
Software Provider
Ontario, Calif.
Do this:
1. Go to the menu Comm. Port
2. Ensure URL is selected
3. Click the URL Setup button
4. Click the Auto Detect button then click the Set Selected Available button.
Rabbitiswise
S.E. Michigan
Will.. little update... There is something on my pc that is blocking.. decided to do a little 3d printing, and can't get to that nor my security camera from my pc.. ugh... not to just find out what it is.
Rabbitiswise
S.E. Michigan
**Update**
Even though I didn't have the program(NordVPN) running it had block anything on my local network. smh... Uninstalled it and it works fine.
