ProScan SDS200 LAN issues
Seymourmtn
Seymour, Tn
Greetings Gurus
New Sds200, latest version of ProScan, LAN enabled with static ID and lights flashing.
In Webserver audio settings, I have select URL and then click on Setup
I have changed the IP address only. No connection. Reconnect diesn’t Connect
Any ideas what the issue Is?
Doug
the IP address,
mm68gto
Barberton, Ohio
A picture is like a thousand words. Can you provide screenshots of the Audio Control -> Source Client tab and the Source Client tab?
Well I messed with it again there are error at the botom. I'm thinkin it a Ausu router firewall problem and I don't know how to get past it. Most device that I've hook to the router or hub requires a user name and password. Look I'm old not an IT person even tho I've gotten by.
ProScan
Software Provider
Ontario, Calif.
What does the error say and at the bottom of what? Post some screenshots.
mm68gto
Barberton, Ohio
Bytes TX and Rx is showing packed being transmitted
No packet loss
TCP scanner port 554
TCP computer port number is always changing
UDP scanner port number is always changing
UDP computer port number is always changing
error TCP not connected
error UDP not connected .... errors seem to blink on and off
eaf1956
Evansville, IN
This is what it is supposed to look like.
Sent from my SM-N960U using Tapatalk
ProScan
Software Provider
Ontario, Calif.
No packet loss
To resolve that, I would do the following:
1. Check the Scanner menu -> Settings -> LAN Settings -> Show IPs - shows an IP address.
2. Make sure the IP of the scanner LAN is entered correctly in ProScan URL Setup.
3. Click the Reconnect button.
4. If errors don't go away then power cycle the scanner.
mm68gto
Barberton, Ohio
See if a scanner power cycle resolves the UDP Not Connected error. If it's still there then perhaps reboot the computer and router.
Ok everyone thanks for putting up with me. So I unhooked the desktop and hook it up to the lap top that I was replacing the original xp computer and the darn thing started working. Hope it stays working if I turn off the scanner Thank again
