It addresses a ton of fixes and requested changes.
SCAN LIST TEXT!!! NICE!
Try using the attenuator,But i suppose you may have alreadyredhelmet13 said:Found a bug - dang it! It has issues with trying to handle a VHF P25 system using Mutipackets - No CC dump unless Supertrack is turned off and then it shows a whole bunch of CRC errors.
Knowing the good folks at GRE, they will have it fixed soon. Othewise everything else is great.
rhalld38 said:Maybe I missed something somewhere. What is the upgrades to 1.2 for?
You still haven't specified which system is this. It's working fine on our P25 VHF system that uses one of Motorola's latest infrastructure software versions (7.X).redhelmet13 said:Found a bug - dang it! It has issues with trying to handle a VHF P25 system using Mutipackets - No CC dump unless Supertrack is turned off and then it shows a whole bunch of CRC errors.
kikito said:You still haven't specified which system is this. It's working fine on our P25 VHF system that uses one of Motorola's latest infrastructure software versions (7.X).
Perhaps GRE might need to check on your specific system to see what's new or different.....
Russell said:I assume this is Parker County, TX new VHF P25 system: http://www.radioreference.com/apps/db/?sid=5636
Russell
Russell said:Excellent! All I can say is great job GRE. I'm ready to buy another one.
This fix seems a bit confusing;
- Changed default "EndtoneMot" value from 250 to 80. The value 80 is used
to correct squelch tails at the end of voice transmissions on narrowband
EDACS systems
It refers to "EndtoneMot" but addresses an EDACS narrowband issue. Is this correct? This would seem like a Mot system parameter.
Russell
stlouisx50 said:This will be my first software update , I am a bit unsure how to do it but, I guess It will tell me on their site?
pogbobo said:thats a nice list of fixes ... wish i had a 500 lol
fmon said:Hey folks,
These updates brought to life
1. a 796.759375 freq which I've had in scanlist 1 for a couple of weeks. Found it during a search, but never had a hit after programming until restarting the scanner after these upgrades. Now it wont shut up. Think it's the Sheriff's dept in Chesapeake by the info they discuss.
hoser147 said:It is actually a Firmware update and you will need to update your software afterwards. The directions are on the GRE site. CPU first and then DSP. Its not to bad and worth the effort. Hoser
