PSR-800 is totally dead
lsh1885
Orlando, Florida
After I used the software to transfer recordings from the scanner to the computer and after removing the USB cable, it is totally dead. I tried to remove batteries, removing and inserting the SD card and nothing helps, I also tried to reattach the USB to the computer and radio, but the software cannot communicate with the scanner. Any Ideas?
DaveIN
Founders Curmudgen
West Michigan
You could try to leave the batteries out of the radio for a few minutes to an hour, and then see if it will turn on after replacing the batteries. Another thought would be to press and hold the MENU key and insert the USB cable to see if it will allow you to do the firmware update from the software.
jackj
NW Ohio
SD card?
The microSD card may have gotten hosed. Take the card out of the radio and put it in a card reader and use the software to reformat it. Then copy the radio configuration to the card. The radio MIGHT work after that. Good luck.
lsh1885
Orlando, Florida
I contacted GRE Support and they said to remove the batteries for 10 minutes and try to power it back on after that. He said to let them know if it doesn't work. We'll see what happens. Thanks for the help.
lsh1885
Orlando, Florida
I removed the batteries for about an hour and it didn't work and notified GRE Support of same. If all else fails and I have to get a new card, are all of them compatible with this scanner. Thanks!
jackj
NW Ohio
I can't answer your question about card compatibility. Did you try using EZscan to format the card then copy the EZscan info back to it?
N0WEF
Mpls, MN.
SanDisk seems to work the best based on what I've read.
lsh1885
Orlando, Florida
Well, I heard from GRE Support and I guess they think It is more than the card, because they want me to sent the scanner back to them for repair.
jackj
NW Ohio
I'm sorry you will be without your scanner for a few weeks. Too bad it wasn't something simple and fixable at home. Good luck.
lsh1885
Orlando, Florida
Just in case this happens to someone else, according to GRE Support even with a bad card the scanner should power on.
lsh1885
Orlando, Florida
I got my scanner back from GRE on Monday, it works perfectly now. In case anyone is curious what was wrong with it, they replaced the logic board and faceplate.
KC4RAF
Davenport,Fl.- home to me and the gators and the s
Glad to see you back up and running
with your repaired 800. For what it's worth, GRE does have great comsumer relationship. I've owned a few of their RS models and always happy with their performance.Thinking about biting the bullet and getting the 800.
ahearn
Woodstock, GA
Great to hear you got your 800 working and that GRE CS works so well. It's one of the reasons I bought my 800. If something goes wrong, it's going to get fixed professionally and promptly.
bigsky109
Sad to hear that your 800 died, but it was really nice to hear about the support GRE offered. Great news in the long run. I hope I will never need the support but it is nice to know the support is good.
lsh1885
Orlando, Florida
I am so glad they were able to fix it, it is a great scanner. I will be going on vacation in Alaska in early May, I am going to take the scanner with me, hopefully I will be able to hear some interesting things.
