Question for Will County HARRIS SYSTEM
tsalmrsystemtech
Would anybody know what the ASTRO P25 Channel ID's are for this system? Most of the time now its in the RR.com Db but this system has not been updated.
Just wonder if anybody can post it here. Thanks.
RoninJoliet
ILL
If you go to the Will Co trunk system list on here and tap "Wiki" it takes you to a abbreviated list of UIDs or if you have one of the newer scanners you can turn on UID and see them ,....
tsalmrsystemtech
Thank You for your response but I am looking for the ASTRO 25 Channel ID's for the back bone of the HARRIS system like using ProCom96 or UniTrunker. Hopefully somebody can help out. Thanks
N9JIG
Sheriff
Moderator
Far NW Valley
If they are not listed in the DB just run PRO96Com or Unitrunker on the system, that should decode that info. Be sure to submit your findings!
tsalmrsystemtech
Thanks N9JIG. I hope you still have that really nice setup with radios all in that rack in Arizona you use to post. I always remembered you.
I just do not live in that area to run PRO96Com. I was hoping maybe somebody that lived in that area knows it or so and then when we get I can submit it to he Db. I think you are a railroad buff too. Send me some PM's on any pictures of your nice setup. I remember you have wall plates with mulitple connections coming out of your walls for all of your Uniden BCT15X and all sorts of radios in that Server rack. Thanks
MikeyC
Utica, IL
Hi,
I don't live in the area anymore, but here's the info from Pro96Com for the system from Jan, 28 2023 -
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0043","d",851.27500,"00-0043",806.27500,0,0
"00-0121","vd",851.76250,"00-0121",806.76250,0,37
"00-0183","vd",852.15000,"00-0183",807.15000,0,35
"00-0271","vd",852.70000,"00-0271",807.70000,0,35
"00-0533","cav",854.33750,"00-0533",854.33750,1,272
"00-0645","cv",855.03750,"00-0645",810.03750,0,241
"00-0745","av",855.66250,"00-0745",810.66250,0,321
"00-0813","avd",856.08750,"00-0813",811.08750,0,330
"00-0861","av",856.38750,"00-0861",811.38750,0,570
"00-1021","cv",857.38750,"00-1021",812.38750,0,457
"00-1281","cvd",859.01250,"00-1281",814.01250,0,58
"00-1345","v",859.41250,"00-1345",814.41250,0,557
I hope this helps :)
tsalmrsystemtech
Hi,
-Frequencies
The format looks a little wild but I think I can work thru this and figure it out maybe. Maybe somebody else maybe can help with the formatting too. But yes, thank you so much for now. If you need any help with anythng P/M for anything too. We also want to make sure we help each other out on things
Sorry but I just do not see the offsets unless I am just blind. :)
tvengr
Well Known Member
Baltimore County, MD
Offset is -45 MHz for 800 MHz frequencies and +30 MHz for 700 MHz frequencies. Mobile frequencies are 45 MHz lower on 800 MHz systems and 30 MHz higher on 700 MHz systems.
tsalmrsystemtech
This is how I added from another Harris System in the past
tvengr
Well Known Member
If it worked on the other system, it should be OK for the new one. The offsets for mobile frequencies are the same for all of the 700 MHz and 800 MHz trunked systems (45 MHz lower for 800 MHz and 30 MHz higher for 700 MHz).
tsalmrsystemtech
Yeah still having some issues with the ASTRO 25 Channel ID's for 0 and 9
Wonder if somebody can sniff on the control channel using Unitrunker or Procom96. Thanks. That would be a great help
ILjim
10+ Years Listening
Wilmette, IL
Slightly off topic, but I thought that the Will Co system was built out by EF Johnson and not Harris?
officerdave
Retired LEO
Yes Will County is on EFJ system. Same type of system as newer DeKalb County. (ATLAS simulcast etc. )
As far as I am aware, L3Harris no longer has any presence in Will County.
usswood
Terre Haute, IN
GTR8000
NY/NJ Database Guy
BEE00
This is the Harris System that I am refering too. So if anybody has the exact ASTRO 25 Channel ID's for 1 and 9 that would be great.
Why do you keep referring to it as a Harris system even after being told that it's an E.F. Johnson ATLAS system?
And it appears that you didn't search the forum posts, because I found the band plan in about 15 seconds. Hint: only a single element is required.
GTR8000
NY/NJ Database Guy
BEE00
Why do you need that info for a P25 phase II system, just for my info, can't you just program the control channels in any order?
He wants the band plan so that he can program a "real" radio. Has nothing to do with programming control channels.
p25man123
DuPage County, IL
Safest place to be at is to get a scanner or receiver to avoid legal trouble. Not a P25 2-Way Radio.
