Questions on Fequency coverage
I recently purchased a Uniden Home Patrol scanner and was wondering if I can listen to municipalities that do not automatically come up on the radio's database. Like today, there is an emergency at a school down the road from me in Murrysville, PA and I hear nothing. I found something about Murrysville in the RR database and it said that it is trunked at 156.0975 MHz. I'm not sure how this works.
Thanks for any explanations!
SkiBob
Out Yonder, GA
According to the wiki there is not a scanner that can decode this. I do believe however, there is a computer program that you feed with your scanner that may decode it. I will refer you back to the link in my post and to others with more knowledge of this.
jfhtm350
New Market TN
You will need a tapped radio and DSD. You will need to do some research on those before you continue. If it is encrypted then you are out of luck.
