R30 R30 Reception
KAZ7ED
My R30 reception is not very good. Seems any of my Uniden Scanners will receive better than the R30, BCD436HP and SDS100, on any frequency. I did a complete reset on the R30 but same results. Maybe the stock antenna is not very good? Any ideas?
palmerjrusa
Frederick
You mean you thought is was?
Stock antennas are pretty much always mediocre.
KevinC
32D2T/957.282
I'm everywhere Focker!
Have you adjusted the RF gain?
Whiskey3JMC
Simulcastylvania, TE
Stock antenna is usually the first thing I toss in a drawer & forget about when I acquire a radio (the stock telescopic on my IC-R20 being the rare exception) Hard to provide any ideas without any info from you on what bands you're struggling to bring in, what your RF environment is like, etc
bearcatrp
Land of 10,000 taxes
Stock antenna is mediocre. Bought one of those antennas (can’t remember the name) you extend for frequencies you want to match. Works great.
KAZ7ED
Thanks. The stock antenna is a telescoping antenna also that you extend based on frequency.
bearcatrp
The Comet SMA-W100RX2 works allot better than stock. Bought one for my yaesu vx 7r to try for reception. Pretty much double the reception. Also put one on my RS Pro 26. Has markings on the side to show what length to use for a particular band.
KAZ7ED
@bearcatrp - I have a Comet SMA-W100RX2 and doesn't seem to make any difference from the stock telescoping antenna.
@cbehr91 - All frequencies, but lets say primarily UHF and VHF.
Thanks!
cbehr91
Thanks!
The R30 blows everything away reception wise I've ever used, so it's very odd you're having issues. Even the stock antenna seemed decent (other than having to adjust it to frequency). Popular scanner-type HT antenna include the Diamond RH77.
KAZ7ED
Well, alrighty then. I think I figured it out. I had Tone Mode set to tsql (with ctcss codes). Set to none and obviously much better reception. Set RFGain to 8 in lieu of MAX.
cbehr91
I've monitored pretty much the R30's entire frequency range and have never had RF gain set to anything other than Max.
G7RUX
The RF gain control has its uses, mainly around frequencies below 40 MHz but monitoring FM or digital modes it won’t be much use. You’d only need to reduce the RF gain really if you’re starting to suffer intermods and blocking behaviour.
vagrant
ker-muhj-uhn
California
I typically have my RF gain set to 7 and adjust as needed depending on the antenna and filters connected.
