Radio shack pro 652
dave3825
Suffolk County NY
The dcs don’t have decimal points so they will copy without issue. You might have to play with the formatting in that column.
dave3825
Suffolk County NY
I might have a solution for you stay tuned. Dinner comes first.
ProScan
Software Provider
Ontario, Calif.
For some reason the get clipboard in proscan is grey'd out and i can't select it.
You either don't have a database file opened or you do but you are not at the group or channel level on a system.
The Get Clipboard works at the channel level. It can import conventional frequencies, trunk frequencies, TGIDs. A system needs to be created 1st then a group (or department) then a site (if a trunk system).
