Radio shack pro 94 free software
RobynRex
does anyone know, if there is any any free software for the radio shack pro94 that is simple to use that i can transfer the frequency to my scanner. I am buying the cable today just need the software. I appreciate any help. thanks Robyn
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
AFAIK does not exist. The only thing out there is (yecchh) Scancat Lite Plus.
Even worse, it's not set up to import data using the web interface for RR, like many other packages. There is a procedure, clumsy though it is, that you can use if you have Excel or similar to pull data - here's the link...
http://wiki.radioreference.com/index.php/Excel_Copy/Paste_Special_to_Software
You would think that the 94 being basically a Uniden product, that someone would come up with freeware that could use the RR import function, but evidently no one has....yet....73 Mike
pappy1
Central Arkansas
There is no software for the Pro 94 scanner. The scanner is not made to use software. Hope this helps.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Not so. The later versions of the PRO-94 have a PC/IF jack on it's side. The older versions don't.
73 Mike
RobynRex
pro 94
it has a PC/IF and I know that radio shack used to program it, but radio shack people doesn't program it very well so I wanted to do it myself. I talk to radio shack and they gave me the cord so I know it works I just need to know what would be a good free software or maybe a cheap version. Thanks
pappy1
Central Arkansas
Then I own an older one as there is not a jack on it side ecept for power. I thought they all were that way. Sorry for giving mis-information. Pappy
RobynRex
It is okay Pappy :) they shouldn't keep naming the new version the same thing it confused me too trying to find info on the web for pro 94
Robyn
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I rather doubt you're going to find anything apart from the Scancat product, Robyn. This scanner is quite old, and since no one else stepped up to the plate insofar as software support is concerned, I'm afraid you're stuck...almost.
There's a fairly active PRO-94 owner's group on Yahoo - it's admittedly a long shot, but it's just possible someone has built Scancat Lite compatible files (or has them) for your area. Here's the link...
http://groups.yahoo.com/group/pro94owners/
and I can't see where you are from (what state, ect.) but there are a great many Yahoo scanning related lists where you *might* find something. I would also inquire in your state's forum here on RR...
Here's a link to our wiki article that lists the scanning related lists...
http://wiki.radioreference.com/index.php/US_Scanning_Mailing_Lists
Y'know, this question keeps on coming up from time to time. It would be a worthwhile project if someone were to store Scancat Lite Plus files for various areas in the country. They could use the Excel paste method I mentioned earlier, and be able to grab data from the database...
73 Mike
[edit] By the way, if you order the software, tell them to keep their Mr.Scanner data junk. It looks like it's 2 years old, and at least in the case of Maryland's listing, horribly out of date. Pure junk.
MistressGwen
HILL CITY, VIRGINIA
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
This thread is almost 3 years old !!
Anyway programming trunking in the 94 is very similar to what you do for the Uniden BC245 - not surprising since the radio was actually manufactured by Uniden. So these instructions work pretty well (I've programmed a few 94s for friends...)
The BC245 Trunking FAQ - The RadioReference Wiki
Mike
