RAN/Area Code Search
garys
Central Texas
For some reason, my SDS200 stopped receiving one of three NXDN trunk systems I've been monitoring. Thinking that weird and being up in the area, I ran that system on DSD+ on my laptop. The system came in very well, as I expected.
Doing a manual drill down into the settings for the site, I found that RAN/Area Code was set to "Search." The problem was that there was no indication that there was searching going on. I don't remember setting the site up that way, because I know the RAN. I changed each site from "Search" to the correct RAN and the SDS started to scan the system perfectly.
It seems that the RAN/Area Code Search function doesn't work as it's intended.
Has anyone else tried this?
enosjones
Price, Utah
Sometimes if it downloads from the database the ran was set to 0 instead of search, also causing a similar problem
garys
Central Texas
I didn't download this system from the database. I'm not even sure it's there. I did the programming after listening to the system on DSD+ and figuring out the LCN order.
RRR
OFFLINE
USA
I was under the assumption that RAN code "0" -was- search?
garys
Central Texas
No, Search is Search, Ran 0 is Ran 0. In both the x36HP and SDS scanners, drilling down in the menu system will show both as choices if you go into the Sites/Frequencies area.
RRR
OFFLINE
USA
How do you search for RAN codes with an SDS series?
RRR
OFFLINE
USA
Yea, that's what I had been doing. Was hoping with such an advanced scanner, there would be a more direct, specific way than just the generic "Digital search"
