Raspi op25 installation
n1moy
Plymouth Co, Massachusetts
2024.Sep.02
Pursuing clarification on the current op25 Raspi build instructions.
Raspi 4B with full 64-bit debian OS [Bookworm] image with:
cmake [v3.25.1]
gnuradio-dev [v3.10.5.1-3]
gqrx [v2.17.5-4-g25fdbb5]
Is this op25 install procedure correct ?
$ git clone GitHub - boatbod/op25: Fork of osmocom OP25 by boatbod
$ cd op25
$ git checkout gr310
$ ./install.sh
Are all the required prerequisites included in the script ?
Thanks in advance,
wgbecks
NE Wisconsin
Yes, install.sh will install all required prerequisite dependencies after switching to the gr310 branch.
wgbecks
NE Wisconsin
Was inquiring if the 'gr310' branch was still preferred.
It's not a matter of preference. You have to select the correct branch to match the GNU Radio version that your OS will install.
To determine this information, query the apt repository. IE: apt list | grep gnuradio-dev
Example-1 (master branch)
$ apt list | grep gnuradio-dev
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
gnuradio-dev/oldstable 3.8.2.0-14 armhf
Example-2 (gr-310 branch)
gnuradio-dev/jammy,now 3.10.1.1-2 amd64
viggendriver
You might want to try using DragonOS...Someone on the forum recommended it and it installs like a breeze with the Boatbod version.
n1moy
Very interesting! My use of 'git checkout gr310' appears to be okay. Thanks,
gnuradio-dev/stable,now 3.10.5.1-3 arm64 [installed]
gnuradio-dev/stable 3.10.5.1-3 armhf
boatbod
Talbot Co, MD
Yes, you do want to be using the "gr310" git branch with gnuradio-3.10 or later releases.
