KE0GXN
I have owned the lacross, the Maha, and the ambient weather / Opus chargers.
When it comes to the lacross charger overheating I can say from personal experience that it does happen. That being said it appears to be more of a quality control issue than an issue that affects every charger. I went through two chargers in a six month period. The first unit I noticed was overheating right away so send it in for an exchange and the second unit made it about six months. The second time I placed some batteries in the charger to be recharged and walked away to fix dinner. About a half an hour later I started smelling a burning smell and came back to find a battery charger mess. On the flipside I have friends who have been using theirs for years with no issues. Out of all the people I know who have had this charger the success rate has been around 50%.
The Maha charger is a very well-built and excellent performing machine. My C 9000 is almost 4 years old and still charging like the day it came out of the box. This charger is great but there are a few things to be aware of. When you charge batteries in the 9000 it will charge the batteries up to approximately 90-95% then it will rely on what they call a top off charge which lasts an hour to finish charging the cells. Four example if you set the charger to charge at 1000MaH it will charge to approximately 95% and relies on a 250MaH top off charge to finish the job. Even though the display reads done it may still be in the top off charge mode so you need to allow for extra time. The charger has a backlight that is very bright and is always on while the unit is operational. I swear you could use this thing as a night light. You definitely want to keep this in mind when choosing where to place the charger. I will repeat what previous posters have said about the amount of button presses necessary. You have to set each individual battery to the required setting. The last thing is more of an observation but this unit is size wise the biggest one out of all the units you are comparing. If you are using it only at home this is obviously not an issue but if you will be traveling with it it is something to keep in mind as it will require a little extra space in the suitcase.
The Opus / Ambient Weather Chargers are probably the newest of the bunch. The first generation of chargers did have some overheating and software issues but the newer units thanks to hardware and firmware changes no longer have this problem. If you purchased through Amazon you will be getting the newest version. As of the time of this post you know you have the newest version by plugging it in and observing the number in the far left column. This number is the current firmware version and should read 2.1. I saw a lot of the same post you did in the other forums but after doing a lot of the research found the majority of them to be from the previous generation. I've had this charger for just over nine months and really like it. The minor issues I had with the Maha do not exist with this one. Batteries are charged to 100% based on the current you select so no more worrying about extra time for top off charging. If you place all of your batteries in the charger prior to plugging it in it will default to all four batteries so you only have to set the settings one time. The backlight even though it is dimmer is still fully usable and goes off after a few seconds of no buttons being pressed. The size is smaller than the Maha but bigger than the Lacross. I travel quite a bit so this means a little more room in my suitcase for other things which is a plus for me. The only thing I have found so far that is even close to a complaint is that when the battery reaches a full charge the display reads full. You have to hit the display button to toggle through the different information and after five seconds the display reverts back to full.
Lastly for rechargeable batteries I am now using the Amazon basics high capacity rechargeable batteries. These batteries are rebranded Panasonic Eneloop Pro batteries for half the cost
http://www.amazon.com/AmazonBasics-...id=1443454860&sr=8-1&keywords=aa+rechargeable
In short you really can't go wrong with either the Maha or Opus / Ambient Weather chargers. Along with the Amazon batteries above it's a winning combination.
As always, thanks for the detailed feedback!
You are actually the member here that got me started down the AB BC-2000 road to begin with in another thread. Sounds like you are extremely happy with your decision to purchase it.
I too am aware of the 95% when done issue and the suggested 1-2 hour top off charge afterwards....which favors one going with the BC-2000. I also would like to set a set of batteries in a charger and just plug and go, instead of having to program each cell. I also like the fact that the BC-2000 has 4 screens, versus the Maha's one big one.
On the flip side, I don't do much traveling, so the Maha's size is not an issue for me, as it will mostly sit on a table in my house.
I actually prefer a charger that has a constant LED light on function (personnel preference).
Given all that, for some reason I still feel drawn to the Maha, if for nothing else it's long, long track record of proven quality and "outstanding" reviews. Your positive experience with the BC-2000 while only 9 months long bodes well with keeping it at the top of my list, however......the fact that you stated your Maha has been owned by you for 4 years and still works like the day it came out of the box carries a lot more weight with me.
