Hi is it possible to reband a bc346xtc so that military air channels can be added to the receiver?
Ray
Ray
Let's watch the terminology here - rebanding strictly applies to shifting 800 Mhz frequencies, and isn't what you're really asking, and unfortunately the answer is no. You can't make a receiver reliably receive on a frequency for which it isn't designed.
Mike
OK. It would likely violate DOC approval.
Maybe try to find that Google hit again.
Approval is for the initial application by the manufacturer. What happens after that has nothing to do with approval.
This version of Win96 does...
Version 1.25 2003.10.03 12:45 PDT
Added options to the Edit menu that allow sorting channels and talk group lists
Added an “extended frequencies” option, which seems to enable some sort of hidden test mode that allows all frequencies except cellular. Frequencies can be sent from Win96, or can be entered directly on the scanner’s keypad (including in SR6 – Limit Search).
Addendum: Some ranges still appear to be "blocked" by the scanner. Here are the ranges that seem to be "opened" with this feature:
17 - 25
54 - 108
225 - 406
512 - 550
764 - 806
960 - 1240
It was also available on ARC96.
My Pro2096 seems to work fairly well with these extended frequencies
Although this wouldn't help the OP
