regency hx1500
rmx77
mukilteo, washington
i recently have aquired an old regency hx1500. i found it as-is in a computer recycle store in the as-is section. the way it was found was with super old leaked corroded ni-cad rechargeable batteries still in it. i had taken the batteries out and cleaned the corrosion off as best i could and i tried to power it from a power adapter i happen to have and the first one i tried it didnt do anything but the second one i plugged in it smoked. i wonder if there is anyone that does repairs on this type of radio and also i would like to know how the unit works. this is my first ham radio and i have been searchin for something cheap to have as a ham i didnt pay much at all for this thing cause of what it was and that there wasnt anything with it. but i would want to know how the radio works like feature wise and if there are people out there that repair this type of thing. i read online that there are people that say this radio is rare now to even have. anyone that has one or a couple usually hold onto them for parts since they dont show up to often. i checked on google to find any info on places that repair them in the seattle area but what i have found is more of places selling new equipment and acesseries for the units they sell. any information would be appreciated
fineshot1
NJ USA (Republic of NJ)
You are saying that this is a ham radio, but it is not.
It is simply an older model scanner that is obsolete.
I had its prior version - the HX1200 and that was a
very lousy scanner in its day.
If you let the smoke out of the 1500 I can assure
you it is not worth resurrecting it.
The repair bill would be probably be enough to
purchase another one or two older model scanners.
rmx77
the reason why i think its a ham radio is because of the low low range it says it receives which is ham frequencies and also it has a push to talk button on the side with a lock switch. i dont know much bout it other then people having frequency error problems with theirs. the radio receives 30-50, 144-174, 440-512, 118-136 which is more ham frequencies then anything else. maybe someone knows a bit more bout it then i do
reedeb
Dallas Texas
I had the 1200 in the late 80's and I loved it till I dropped it and it died. BEST portable scanner I had at the time.
fineshot1
The so called PTT button is not functional for PTT. If I recall correctly it only turns on the LCD back light.
The only ham freq ranges it receives are 144-148 and 440-450, the rest is commercial spectrum.
There are no single commercial two way radios that can transmit in all those freq ranges, IT IS A SCANNER and has no transmit capability.
Yes - the 1200 I had, had an awesome receiver but it also generated a million birdies and was useless
in search mode and was only able to use it to listen to one freq at a time. I was so frustrated with it that I made it fly.
Ensnared
Waco, Texas
Regency HX1500
I once owned a Regency HX-1500. Although it is now obsolete, it was a solid radio. If I am not mistaken, this radio had shielding inside to help reduce interference. I loved this radio. In fact, I liked most Regency scanners with the exception of the MX-7000 (keypad died).
But, I agree, it is not worth the cost of repair since it is indeed obsolete for most applications.
