Relay server problem?
nunyax
Walton County, GA
My feeds are up by I can't connect to them. Web player shows "waiting for relay.radioreference.com..." message and can't connect using any other player as well.
sideshowbob
was having the same problems with the web player. I was able to get winamp to connect, although it did take much longer then normal.
jasonpeoria911
Peoria, IL
Yah i'm sure RR lost a few audio servers. With it being so late, Lindsay might be snoozing but i'm sure he'll be up bright and early to get everything reset. Total feed listeners went from about 10,500 to 2,200 so it's an overall audio platform problem.
Jason
ffexpCP
wizard of odd
Michigan
I tried to listen to mine, and couldn't get to it. My side of things are just fine.
I also tried listening to some others with the same results.
longreach
Southern Tablelands NSW Australia
Hi all, yeah having the same problem, its showing online and i can connect to the decoder directly(bypassing RR). oh well im sure it will be sorted quickly.
cheers
Matt
crazynova
I'm having the same problems. This sucks because the scanner is used to help me go to bed.
Ayi
When connecting with my iPhone from the RR website using the iTunes type I get "You are not authorized to open this file". On PC I just get the red X after it tries any feed with the web and java players.
davidkc
Bathurst NSW
Yeh here in Australia my feed wont work either, in web player small red x in the screen.. Glad its not my setup, had tried everything then thought better look in here.
