Freescan: Remote control app for Android
nick0909
Antenna flicker
I have created an unofficial Android app to remote control Freescan, similar to the official app for iOS. It seems fairly stable for my uses but I have only tested it on my BCD396XT and a few mobile devices. If there is interest in others using this I could make it available and hopefully improve the experience as we test it further. Anyone interested in testing it out?
nick0909
Antenna flicker
That is strange. I am doing that and more on my phone and two tablets and they all save and load properly. What device are you using and what Android version? I'll make some adjustments and see if I can spot some kind of race condition that might exist.
rbm
Upstate New York
I'm using a Droid Maxx.
So this morning I got my wife's Droid Maxx and tried it also.
My sequence to add a Preset was 'flawed'. ;)
I hit 'Add Preset'
Entered the data ....
Then hit 'Save Settings"
Should have been:
THEN .... 'Add Preset'
(I hope I recall that correctly. But that's where the problem was. In the sequence.)
So all is good. Sorry for the false alarm.
Rich
nick0909
Antenna flicker
Ah yes... the 3 preset buttons are totally independent of the save settings button, you can add as many presets as you want while in the settings screen and then save settings moves you back to the scanner display and uses the settings last entered. I have put in a check already so it won't add the same preset more than once, I will try to relabel some of the buttons to make my intentions clearer. There should be a new version today or tomorrow with the changes. Thanks!
rbm
Upstate New York
Nick, your app should come with a warning! ;)
You now have me 'rewiring' some of my scanners and adding a few more 'private' feeds.
I'll probably also set up one (or more) of them so local listeners can select what they want to hear.
We'll see how that goes.
I thought I had enough scanners for a while.
Now you have me looking for some used BCD396 and BCD996 scanners.
Rich
rbm
Upstate New York
Well .......................
I have 5 scanner feeds set up for remote control now.
Not that I 'expect' to need that many.
There have only been two times in recent memory where I needed that much.
One was widespread flooding a few years ago, and the other was a mass casualty/shooting event about 5 years before that.
But, it's always good to be able to lock a scanner or two on one frequency and still scan others.
I'm using 5 players.
Scanner Radio
Scanner Radio Pro
Xiialive
TuneIn Radio
A Online Radio (AOR)
I think I'm good for a while.
Thanks again,
Rich
nick0909
Antenna flicker
0.7.1 has been released on the play store, it should show up in a couple of hours. It has a new icon! So don't freak out when you don't see Nixon like you are used to. I figured I might as well make something a little more "descriptive" than the picture I had, but my artistic skills are low. But its better than nothin. It also has some changes to how the preset buttons are displayed so hopefully it is clearer how they work and has the fix so it won't let you add the same preset multiple times. Enjoy!
smason
Alberta Canada, Eh!
I may need to fire up Freescan and try this myself.
You should contact Bob and see if he's interested in collaborating with you on a version for Proscan.
I've always wanted a remote phone app for Proscan.
nick0909
Antenna flicker
I have never used Proscan, it depends on how the remote control protocol works if I would be able to do it or not. I am open to trying.
rbm
Upstate New York
Nick, thanks again for your app.
After a few weeks of using it, I don't know how I got by without it. ;)
Today there were two major events in my area and I was able to 'lock up' two of my feeds on the important systems.
Rich
nick0909
Antenna flicker
Hey great to hear! If you happen to come up with anything you want to see improved with it, let me know, but I am pretty happy with it right now. Hope it can be useful to people!
Nick
lsmith8706
I just stumbled across this app, and I love the control and ease of use! Any chance you are going to add the ability to stream audio with? I use it for a private feed (One not run through or any other website/app) that uses scannercast, and as far as I can tell, there's no way to add the audio from it. I can do it other ways, but It'd be sweet to have it all in one app. I'd be happy to be a tester too!
rbm
Upstate New York
RemoteFS is a great app, I use it all day every day.
I have a lot of private feeds (7-12) and use SannerCast & RemoteFS on all of them.
That way, I can use Scanner Radio, Scanner RadioPro, TuneIn Radio, and A Online Radio (AOR) to listen to multiple feeds.
Rich
All of these feeds and more:
nick0909
Antenna flicker
Thanks for checking out the app! My main goal was to be able to control the scanner from Android and do that well, then I thought others might like to do the same so I published it.
The most requested feature so far has been to add audio streaming, so I have been looking in to it. This week I created a version that includes audio streaming, but it is not my wheelhouse and I am not too thrilled about it so far. My first concern is the audio will never match the screen display because of buffering of the audio. That would happen with my app or anyone's streaming app, just because audio has to buffer a little to stream smoothly. If I am honest I am worried about the mountain of complaints about how the audio and the screen display are seconds apart.
Also I feel like the audio streaming I could do in my app would be far less optimized than an app that has a sole purpose of streaming audio. There are a lot of media apps out there that can stream from Broadcastify or your own private feed, and that is their focus so they will do it better. They will probably be better on battery usage and have features like EQ and more decoding options than I could ever hope to achieve.
So anyway, those are my excuses for not adding audio, but also I am working on it on the side. I might put it in if I am happy enough with how it works, but I want to stay true to my main goal, and that was to have a good app (the only app) that lets you control Freescan from Android and let the piles of streaming apps already on Android do that thing.
Nick
nick0909
Antenna flicker
Well I have not been happy with my abilities to add streaming so that is out for the next update. However I am working on a new version with buttons for Vol & Sql +/- for non-handheld scanners. This has also been requested a few times but I only have HH's so I was unable to test the feature, but a gracious fan of the app loaned me remote access to their scanner so this should be ready soon.
rbm
Upstate New York
I, for one, can live without a streaming feature.
I have 11 private feeds and 5 of them are set up to be controlled with your RemoteFS app.
It works great, especially for any major event.
I've had to control as many as three of them remotely when something big was happening.
Locking them on a single system and single frequencies in other systems.
I just use Scanner Radio, Scanner Radio PRO, XiiaLive, etc. for streaming part.
Then, I use RemoteFS to do the control for all of those feeds.
Again, my compliments on a nice app.
Thanks,
Rich
BoltonBill
Hi is this app still available? I can't see it am I looking in the wrong place? Could somebody please point me to it.
Bill
