Mike48824
Ok thanks!im gonna check them out!
That would be a good price, providing it is in good working order, and the seller can be verified as not a scam.I came across an sds100 with accessories for $500 like new?Should I grab it? Thanks
There are two trunked systems in your county. The older one is a Motorola Type II system, which the HP-2 can handle without an issue,Yeh I do like the HP-2 but was told that it wouldn’t work well in Suffolk?
Check the link he provided. If you are extremely lucky, and in the exact right spot, the HP-2 might work. But it's much more probable that Simulcast issues will effect you, so I would also lean away from the HP-1.Anything other than the Uniden SDS scanners will be hit or miss as far as usable reception for simulcast systems as far as scanners go.
Have a read here:
Simulcast Distortion - The RadioReference Wiki
wiki.radioreference.com
Suffolk County Trunking System, Suffolk County, New York
Suffolk County Trunking System Profilewww.radioreference.com
However, there is a newer, P25 Phase II system, that agencies in the county are migrating to. (See the notes on your county's database page.)
This is the newer system:
And two of it's sites are Simulcast.![]()
And fxdscon's comments on Simulcast are also accurate:
Suffolk County is NOT simulcast, and most of it is not digital at this time. I used my HP2 there today, reception is perfect.
I have no way of knowing. Perhaps review the threads in the New York forum to see if anyone has commented one way or the other.It might work, or, instead, work so poorly you want to airmail it out the closest window.I’m in Huntington so you think it would be alright?
If you could get the SDS100 you mentioned earlier for $500, that would be best (again, if you can confirm good working order & a seller that's reputable.)
If, instead, you first wanted to try an HP-2 or 436HP (portable) or 536HP (base mobile), then only purchase from a seller that would let you return without a penalty (restock fee).
As already mentioned, simulcast problems are extremely location specific, even down to the point that moving the scanner a few feet in one direction or another, inside your home, can be the difference between working, or not.
There is another option, other than the SDS series scanners, or the Unication pagers. This receiver is also reported to work well in Simulcast areas:
There is a long discussion thread on it in the forums.
P25RX P25 Phase 1/2/DMR Receiver With Bluetooth Audio Support
https://bluetailtechnologies.com Open-source Configuration software https://github.com/bluetailtech/BTConfigforums.radioreference.com
Here is what you do..... all of the comments above are relevant to hp series. Buy the hp 2 from reputable dealer with liberal return policy and if it does not work to your liking send it back.. done.Thanks!The ladder seems way to complicated for me!lol
as of now it works perfectly in Huntington and every other place in Suffolk County I have been. It is NOT subject to simulcast distortion at all, and again, most all of the talk groups are analog. No telling what the future will bring, it will go digital (which the HP2 does fine) but it may be simulcast OR encrypted.
Bottom line:
You do NOT need an SDS200 NOW. Any modern trunking scanner will work fine.
In the future, it is possible that only the 100 or 200 will work, or it is also possible that NONE of them will work. Nassau has been encrypted for a few years, so for me the 200 would be throwing money away, it won't do anything that my other scanners can do.
Best bet, IMHO, is go cheap and see what happens. If they upgrade to a system that the 200 can handle, you can go for it then. If they go encrypted, you just saved a lot of money. $700+ is a lot of money for a scanner that can not receive the local PD!
