Richmond County on P25 system
Jacob
Grovetown, Ga
20895 Augusta North PD Dispatch
Should be North Augusta PD SC not to confuses with Augusta/Richmond Co North Dispatch
kg4wbb
Martinez,Ga.
Richmond County TG
New one found today that seems to be the Marshals office. Spoke about judges , paperwork and such. I'll give a long listen to see. You guys try it and see what you think as well. New TG 55228
Jacob
Grovetown, Ga
Yes, that is what I have. Richmond Co Marshal's Dispatch 55228. I also have 55201 as Augusta/Richmond Co Sheriff North TAC 55201, South Dispatch 55206, North Dispatch and I not really sure about this one 55236 South TAC.
Jacob WD4EHW
f4jmk
Mitchell,GA.
I have 55201 as North Dispatch, hearing 1000,2000, 3000 and 4000 series call signs , guessing Zones 1-4 cars.
55203 as North TAC
55206 South Dispatch, hearing 5000, 6000, 7000, and 8000 series call signs, guessing Zones 5-8 cars.
55208 as South TAC
55218 as ARC Traffic, mostly T-units here.
chgenoe2
Augusta, GA
55203 as North TAC
55208 as South TAC
I'm still feeling stupid over this. When I try to download the P25 talkgroups I still don't see any of these frequencies listed under Augusta Richmond County. Will Radio Reference eventually add these?
c4181
Jacksonville, FL
55203 as North TAC
55208 as South TAC
They patch channels together at night and if I remember correctly Traffic & Spec Ops gets patched at night. I heard numerous S units & T units on what came up as 55218 last night.
I'm currently hearing GSP units, T units, and traffic accidents going out on 55237 this morning and I've seen nothing on 55218.
kg4wbb
Martinez,Ga.
Hurricane Relief
In case anyone is interested TG 55239 is the TG for Hurricane evacuees coming into Augusta going to ARC and Westside. Same set of 800's as RCSD.
kg4wbb
Martinez,Ga.
Richmond County TG
I'm still feeling stupid over this. When I try to download the P25 talk groups I still don't see any of these frequencies listed under Augusta Richmond County. Will Radio Reference eventually add these?
The 800 meg frequencies are the tower frequencies. Numbers starting at 55 like 55201, 55243 , are Talkgroups ( TG's ) . That's what we are all working on now ; a complete list of Talk groups for Richmond County on the Augusta 800 meg frequencies. Then we will post all of them.
kg4wbb
Martinez,Ga.
Richmond County TG
Program in all the Augusta 800 meg frequencies , making sure that they are P25 and that your scanner does P25 ( check your manual ) , then see if your scanner can scan those frequencies as a Wildcard. That means anything that is on those 800 meg P25 frequencies will show up as starting with 55 ( as in 5501, 5502, etc ) . These are Talkgroups in Richmond county. Hope this helps. Let us know what you find and hear.
Jacob
Grovetown, Ga
Palmetto 25 Augusta-Richmond Co TG
On the Traffic, and Records see if you can tell if it North or South. Events I believe has 3 channels and Special units not sure. The business patrol channel ( patrol mainly downtown area) also has a TAC and record channel.
gemini1030
The Database is no where near correct on one page and then very incomplete on another.
I do know that 55223 is Event 1, 55206 is RCSO South Dispatch,
I am still trying to identify what some of the others are.
c4181
Jacksonville, FL
Spec Ops should have a dedicated Dispatch Channel. I think they have a dedicated TAC channel but I couldn't ever find it before the switch so I may be wrong.
kg4wbb
Martinez,Ga.
Hurricaine Shelters in Augusta
TG 55239 also seems to be an Event TG for Richmond. May be Event 4 . They are able to go from 55239 to Dispatch on the sheriffs department. Thanks for the new updates. Good job.
chgenoe2
Augusta, GA
Hi kg4wbb,
So once they are posted will RR update their download list? In my ARC500 interface when I go to Trunked systems for Richmond County I select P25. Once the Site and Talkgroup lists come up I expand the Augusta/Richmond county talkgroups just to see what's listed. I get 55201,55202,55206,55207,55238 and then up from there. So none of the frequencies listed on the thread show up. I'm still pretty new at this, so do I need to try to program them manually? I am using a Whistler 1065.
Thanks to everyone or their help.
Chuck
c4181
Jacksonville, FL
Hi kg4wbb,
Chuck
They aren't listed because they haven't been added to the database yet.
Everything in this thread is just a discussion of us trying to figure out what different talkgroup are.
As people identify what they are, they post to the database and it will show up in the ARC download list.
You can program anything manually, setup a wildcard (all talkgroups in the system will come through your scanner), or wait for the rest to be identified and then download them.
gemini1030
This is what I can verify so far.
55220 Business Tac
55201 North Dispatch
55203 North Tac
55202 North Records
55208 South Tac
55207 South Records
55218 Traffic
55220 Traffic Tac
55223 Event 1
55224 Event 2
55225 Event 3
55247 Fire Dispatch
55241 Fire Tac 1
55242 Fire Tac 2
55243 Fire Tac 3
55244 Fire Tac 4
EMS 1
55266 EMS 2
EMS Tac
If I can get more I will post
chgenoe2
Augusta, GA
Okay, so I programed in the frequencies everyone is listing and I'm finally receiving. At least more than I was before. Thanks again!
kg4wbb
Martinez,Ga.
Info Please on SC Interoperability Talkgroups
[Could one of you fellows direct me to how I can get more info on SC Interoperability. Is this just on the coast line and what 800 meg group does it dispatch from. I would like to monitor this. Thanks
c4181
Jacksonville, FL
I'm not sure what you mean by SC Interoperability. The Mutal-Aid and LE Common channels are used for various different things.
I'd ask this in the SC Discussion forum though. You won't reach as many people in the Georgia forum.
