FHOP
So, here is the situation. I am new to amateur and commercial radios and their respective programming applications. I just purchased an iCom F-6021 UHF radio, and the programming software as well as a USB cable that plugs into the microphone port on the radio to interface it with the PC. So, after installing the programming software on my Windows 7 laptop, I plugged in the USB cable to the radio, then powered up the radio, and opened the software on my laptop. Windows did it's thing with trying to find a driver for the new device, and it failed to do so, but I didn't think that it mattered anyways. when I tried to read the radio (it is factory fresh out of the box, this is my first time powering it up), I get an error message saying that there is no response from the transceiver, and it tells me to check my COM port settings, make sure the transceiver is powered on, and check the physical connections on either end of the USB cable. I know the transceiver's power is OK, and the cable connection is just fine. However, when I looked in device manager on my laptop, to try and find out what the settings were like for the COM ports, all I found was the new USB device listed, which I could do nothing with besides trying to download a driver that doesn't even work. So, I'm stuck here, and if anyone could help out, link me to some instructions, or just drop a few words of advice, PLEASE do so, it would be much appreciated. Thanks in advance!
