RTL-SDR Windows 11
Lebowski
OG Member
Albuquerque
I cannot get the RTL-SDR Dongle to work on a Windows 11 machine. I've tried till I'm blue in the face on more than one system...cannot get a driver to work. Should I just spin up a Win 10 or Linux VM? Or can someone point me to something that works? I found a few YouTube vids etc. and they don't work.
Thanks!!
lwvmobile
DSD-FME
Lafayette County, FL
Never had an issue getting an rtl dongle to work in my Windows 11 VM, so I really doubt Windows 11 is the issue. Could be a dead dongle, USB related issue, or user error.
lwvmobile
DSD-FME
Could also be YouTube videos fault. I've found those can be unreliable with out of date information, or out of date people making them.
Download Driver 2.7 64-bit driver from:
Install on bulk in interfaces, or on composite hub, can't remember which. Depends on the application, I think.
SDR# also requires the rtlsdr.dll or whatever in its folder I believe, don't think its in there by default if memory serves.
Lebowski
OG Member
Albuquerque
Thanks, did that a few times. I think I may actually have a bad dongle, never occurred to me.
jocam29594
i have the same problem but i installed parallels on mac pro m1. I could not install rtl-sdr v3 in the virtual machine, neither win10 nor win11. I installed Kali Linux on the same mac and I didn't have any problems with it. This is how I set up parallels VM windows 10 and 11 to a mac computer with an m1 processor.
lwvmobile
DSD-FME
So, do you have anything at all in your Device Manager with the dongle plugged in, like this:
or this?
I've found that if you use Zadig, hit Options and check List All Devices, and uncheck Ignore Hubs or Composite Devices, I have better luck getting some applications to play nicely and enumerate the device index correctly with software (like librtlsdr and RTL_FM) if you install the WinUSB driver directly onto the RTL2838UHIDIR device. Just worth a shot to check and see.
Oh, and just for claification:
Is this on an X86-64 machine, or something like Apple Silicon ARM chip?
Dirk_SDR
Germany
Thanks!!
No problems here with W11.
You don't have to "get a (Windows) driver to work". Only install Zadig. If the installation is possible (with a recognized RTLSDR stick!), then everything should be ok.
Then the SDR software (SDR#, HDSDR, ...) should recognize the stick.
New versions of SDR# already contain the .dll for the RTLSDR sticks.
maus92
The OP
Composite.
KevinC007
Fort Worth, TX
I've got nothing working. Install software, plug in SDR and seems laptops doesn't recognize the stick.. This should have been "easy" according to all people. I'm not a computer guy.
Help anyone?
maus92
The OP
Help anyone?
You need to download the Zadig software to install the correct drivers correctly for your SDR sticks. If you are not a "computer guy," find one to help as SDR programs and devices require some amount of computer literacy.
sjacket99
FuzzThePiGuy
Pa
Help anyone?
Here's a link to my website on how to setup the driver. The video also shows how to change the serial number also. But you only need the driver. Website Link.
MP00047311
Thanks!!
Similar problem in Windows 11 (Dell 7220 Windows 10 upgraded to Windows 11). I know about radio and know about computers, but am challenged by getting the RTL-SDR to work. I've had it working on Android, at least one broadcast FM station (93.1) and it appears to work for AIS (161.975 (Marine ch 87) and 162.025 (ch 88)) but the Android device has only one input so I can't charge and run USB at the same time. Not useful if you need full time AIS. Zadig appears to work. In SDR Sharp, in one configuration, I appear to get random noise at a default frequency, but can't figure out how to get SDR Sharp to receive the frequency I want. I get nothing on the display. The help videos on Zadig and SDR Sharp appear to be for old versions that simply do not work when I'm looking at what's installed. So it may be one of those "where's the 'on' switch" problems. (1) driver (2) receiver operating software (3) select the correct frequency (4) "run"?
maus92
The OP
Zadig / rtl- sdr / airspy works fine on Win 11 Pro. Doing an in place upgrade from Win 10 to Win 11 however is an imperfect procedure. I always start with a fresh install of a new OS version with Linux and Windows.
PDXh0b0
Woodland, WA
Watch the first 3 minutes
