RTL-SDR
XPS720
Windham County, Connecticut
Well I am not sure if this is how it works but I need to select V3 on definitions. I found out if I use an IP that supports this device it will work:
78396
I did find out that the antenna connector is unscrewed and no antennas work. Now if the antenna was to work I see that the IP only last 30 min. So is this how it works, connect to an IP?
DRL-XM43
Durham Region
Can you confirm you ran Zadig and installed the driver for the dongle?
If you did not then no SDR will work for you.
XPS720
Thank you as it was that Zadig and now it does identify the RTL. Thanks , but it is old and it looks like the antenna input is broke so I will a new SDL as it is cheep. Thanks again.
jonwienke
More Info Coming Soon!
VA
You need to find the RF gain setting for the dongle and turn it up.
Ubbe
Stockholm, Sweden
When you hold the mouse pointer in the spectrum display it should show a red bar with the texts Scale, Low, High. Set that to show dBm and high can be -20dBm and low -120dBm, or whatever you think would be appropriate.
/Ubbe
XPS720
Well I like this new device as it does receive new area, new frequencies for me. I did notice that the LW works but I hear nothing on MW. Do I need to set up something for that band?
Thank you,
k1zxx
Connecticut
Hello Group, I have a lenovo t410 with windows 10 this laptop has 4 USB ports one on the right and 3 on the left, after setting everything up i can get the right side dongle to work but the left will not start, when I pull the left out and place it to the right the unit works flawlessly for both dongles, for some reason the left side 3 USBs will not allow me to start the unit in unitrunker. now I looked to make sure I properly installed all the necessary software and drivers correctly several times, this did not solve my problem. so i purchased a usb hub for the rite side input to see if this will help, my question is = should or can i get the left side working properly with out the usb hub in the device manager?
or is there some trick to getting my dongle working on the left side, the computer recognizes the dongle but it WILL NOT SART any help ?
Ubbe
Stockholm, Sweden
Confirm that the ports work by inserting something else, USB stick or a mouse. Go into windows controlpanel and the hardware and there you have the USB ports setting. Check that they all are set to not go into sleep mode.
/Ubbe
XPS720
I did find out that the RTL-SDR does not go below, say around 25 mhz, so I look for a new one. I did find this one:
Nooelec NESDR Smart HF Bundle: 100kHz-1.7GHz Software Defined Radio Set for HF/UHF/VHF Including RTL-SDR, Assembled Ham It Up Upconverter, Balun, Adapters & Cables
on Amazon for $89. Does anyone have this or similar to it and is it a good package to get. I will spend up to 100.
jonwienke
VA
Actually, the RTL-SDR V3 goes all the way down to DC if you switch it to direct sample mode. I/Q does 24MHz and up, direct sample does 24MHz and below.
XPS720
Well I did look up the way it can be done but I will not install something that requires a lot of my info just for a file. Unless this direct sampling mode is located, and where, I will not sign up.
jonwienke
VA
In SDR# direct sampling is one of the configuration options. No files or personal info needed. Why are you trying to download anything?
XPS720
Well to let you all know I can hear MW now with the RTL-SDR as I did find the configuration and picked the one with Q. Here is a sample of what I see and hear. Now it is to do a setting for better listening.
78675
Thank you all as this device is better than my ICOM IC-R75.
Happy New Year.
XPS720
And it's even better with a Spyverter connected!
Yes I did see the video of this device and I did get the full package at Amazon with
Nooelec NESDR Smart HF Bundle: 100kHz-1.7GHz Software Defined Radio Set for HF/UHF/VHF Including RTL-SDR, Assembled Ham It Up Upconverter, Balun, Adapters & Cables. I just hope the assemble and software, what software to use, is easy to do. As you can see by my photo I use SDRConsole V3. Again thanks for helping to get me started with this kind of device.
XPS720
I need a reset on my SDRConsole V3 as I must of changed a setting, trying to explore. My LSB and USB are hard to listen to. No matter where I place the | | listen markers the side band is way off. I did try calibration reset but no good. Help me get my HF MB SSB back.
Thank you.
