Saia
joespca1
Who knows if the new system will be fully encrypted and how did they find out that information?
joespca1
The information direct from a source at Saia is the system now has some active subscribers and it will be fully encrypted.
I was thinking of going on the system for my business. I wonder why they want to encrypt
lkas
Cheektowaga NY
are all current subscribers going to switch to the new system when it goes live and therefore everyone on saia will be encrypted?
GTR8000
NY/NJ Database Guy
BEE00
The CapMax system is already "live" with some having already made the switch, and yes, every talkgroup will be encrypted.
BTFire21
NY
Yes, eventually all users will be migrated over to the CapMax system and be encrypted.
k2hz
Rochester, NY
My info from Saia is that existing Con + users will eventually migrate to CapMax, and use the same TGIDs. The Saia CapMax system will be fully encrypted.
What was not stated, and I did not ask assuming it was possibly not yet firmed up, is any schedule for migration or if it will be mandatory at some point. What is clear is that some have opted to upgrade and made the switch already.
Saia is still engaged in building out sites for CapMax including new sites and relocation or upgrades of existing sites. Site 32 Castile is new and Site 29 is being upgraded to higher power and moved from Highmark Stadium to the Orchard Park water tower. So it is still work in progress with more sites pending and I expect to have some updates as the buildout work and migration of subscribers progresses.
I need submissions of any existing Con+ frequencies that have been converted to CapMax. They will need to be removed from Con+ in RRDB and deleted from your Con+ programming or the scanner may have a problem in continuing to track the Con+ system.
So DSD+ observations of both systems will be of value. Not much point in programming a scanner for CapMax as there will be nothing to hear but observed site and channel information can be useful if the scanner can display it.
In any event, I don't expect any mass migration of subscribers before the CapMax system buildout is complete to support it.
k2hz
Rochester, NY
I have been advised the plan is to migrate all Con+ subscribers to CapMax but it could take up to 2 years to complete due to the thousands of radios involved and other issues. But, the migration has started and system buildout is progressing. So both subscriber units and Con+ channels will eventually all be converted to CapMax.
If you are monitoring an agency on SaiaNet now, be aware it will eventually go to encrypted CapMax. If they have an associated unencrypted conventional system, that will not necessarily be affected.
So, if you are considering buying a scanner to monitor SaiaNet be aware it will be gone in the near future, some agencies sooner rather than later.
Wackyracer
That will be a major blow to the scanner hobby in Erie county NY.
k2hz
Rochester, NY
CapMax Site 23 is now active on 463.550 so that frequency is deleted from Con+ at the site.
BTFire21
NY
Sign of the times. Think about how often we are discussing SaiaNet on here and I know for a fact their are employees are on here reading everything. When they started building a new system instead of asking the question of why to encrypt it more likely was why wouldn't we encrypt it. With the excellent coverage they have within their system I am sure the coverage loss due to encryption is negligible.
As great of a resource as Radio Reference is it's also one of its detriments.
BTFire21
NY
Rumore has it Depew PD going P25 encrypted.
I hope they use Motorola instead of Kenwood's ridculous implemnation of P25. Town of Tonawanda has had so many issues that Kenwood has been working nonstop to rollout firmware updates to correct the issues.
GTR8000
NY/NJ Database Guy
BEE00
There is a bit of irony in that statement, given some of the history of an outfit like Saia directly contributing info to the RRDB over the years. I'm neither confirming nor denying that Saia have done so, but I will confirm that things are not always as they appear...lots of behind the scenes stuff goes on around these parts.
BTFire21
NY
I am 100% aware...
Trbogeek
Batavia, NY
Where did that info come from?
In talking with some connected with the village, it was stated that PD is doing this. That being said, I didn't hear it first hand, so it's tagged as "rumor" (mis-spelled in previous post)
