San Francisco Public Safety going Digital June 2021
officer_415
SF Bay Area
Dispatch is unencrypted on A1, A3, A5, and A7. Units are encrypted. This is indicated by a lowercase "e" in the database.
All other channels marked uppercase "E" in the database are fully encrypted.
Hyd25
Not so sure about that...? Seems to me the dispatches on SFFD A1-A2-A3 are still assigning Tactical/ Fire Ground channels in the same way (still on repeater). I do know that an individual operator on the fireground can swithch off to Direct if he/she is on A-09 thru A-16 ?
Right at this time there is a drill going on Fire Ground A-09 which is being repeated.
rustyhodge
I like to listen
San Francisco
So the Direct Channels are digital, but according to the db, not encrypted. I need to figure out how to program my scanner to get non-trunked digital :)
KG7PBS
Sacramento CA
It’s a softkey in the menu on the APX6000. And you can Assign a button to do direct and repeat as well. For me my UHF/VHF XTS2500/5000. The emergency button is set for direct on and off. So any frequency I setup as a repeater I can hit the emergency button and it automatically makes that channel direct frequency
KG7PBS
Sacramento CA
Not bee and A$$. Programming conventional into a scanner is way easier than Trunking I cry for you
Hyd25
These are listed:
Frequency License Type Tone Alpha Tag Description Mode Tag
851.93750 WQYG201 M506 DPLSFFD DIR 1 Fire Direct/Talkaround 1 FM Fire-Tac
852.31250 WQYG201 M506 DPLSFFD DIR 2 Fire Direct/Talkaround 2
But do not make sense to me , since I hear dispatch assigning Fire Tac channels A-11, A12, A13 downward?
Hyd25
KG7PBS comment makes a lot of sense , for a button assignment on the APX6000 [direct/repeat]?
sffire
SFO area
SFFD units respond on A1 -A3. They are assigned a TAC Channel(TG) A7-A16. First arriving unit gives an accessment to the responding Chief on A7-16, then switch to Direct (non trunk) TAC direct C7-16) on the C bank on fireground.
852.17500 WQYG201 M293 NACSFFD C7 Fire C7 Direct P25 Fire-Tac
852.31250 WQYG201 M293 NACSFFD C8 Fire C8 Direct P25 Fire-Tac
859.43750 WQYH975 M293 NACSFFD C9 Fire C9 Direct P25 Fire-Tac
860.43750 WNNF327 M293 NACSFFD C10 Fire C10 Direct P25 Fire-Tac
860.46250 WNMP522 M293 NACSFFD C11 Fire C11 Direct P25 Fire-Tac
852.17500 WQYG201 M357 NACSFFD C12 Fire C12 Direct P25 Fire-Tac
852.31250 WQYG201 M357 NACSFFD C13 Fire C13 Direct P25 Fire-Tac
859.43750 WQYH975 M357 NACSFFD C14 Fire C14 Direct P25 Fire-Tac
860.43750 WNNF327 M357 NACSFFD C15 Fire C15 Direct P25 Fire-Tac
860.46250 WNMP522 M357 NACSFFD C16 Fire C16 Direct P25 Fire-Tac
Hyd25
Of course it's munch more interesting to listen too when everybody is on repeater on the fire ground!
Hyd25
852.17500 WQYG201M293 NACSFFD C7Fire C7 DirectP25Fire-Tac
852.31250 WQYG201M293 NACSFFD C8Fire C8 DirectP25Fire-Tac
859.43750 WQYH975M293 NACSFFD C9Fire C9 DirectP25Fire-Tac
860.43750 WNNF327M293 NACSFFD C10Fire C10 DirectP25Fire-Tac
860.46250 WNMP522M293 NACSFFD C11Fire C11 DirectP25Fire-Tac
852.17500 WQYG201M357 NACSFFD C12Fire C12 DirectP25Fire-Tac
852.31250 WQYG201M357 NACSFFD C13Fire C13 DirectP25Fire-Tac
859.43750 WQYH975M357 NACSFFD C14Fire C14 DirectP25Fire-Tac
860.43750 WNNF327M357 NACSFFD C15Fire C15 DirectP25Fire-Tac
860.46250 WNMP522M357 NACSFFD C16Fire C16 DirectP25Fire-Tac
So does that mean you have to be on scene to here the transmission when they switch to "C", in order to hear them [Line of Site?] ?
