San Francisco Public Safety going Digital June 2021
KD6JEK
San Francisco
Watching the system take shape continues to be fascinating. TGs seem to come and go from day to day as radios are tested and issued to people on certain tours. There will be hours of silence and then SFFD will come up for the evening. Some SFPD district TGs light up for all-channel transmissions and then temporarily for a shift or two, then go dark.
Some TGs are predictable from the legacy arrangement on the analog system. But there are also TGs, especially between other TGs in the SFPD and SFFD blocks, that are popping up and suggest either new assignments or perhaps errors. Is it typical for odd TGs to pop up in testing but not get programmed into radios?
And does anyone have any confirmed lists other than what you can compile based on air?
My analysis tool is a P25RX running its own software.
rustyhodge
I like to listen
San Francisco
I think I've got my 996p2 programmed properly for the SF P25 Phase II system. I should have all PD and FD talkgroups programmed.
So far what I'm mostly hearing is SFFD A3 (tg929) and a bit of EMS4 (TG959).
And I don't know if it's just me, but I find the digital talkgroups a lot harder to understand than the analog ones.
footage
Pacific Rim
footage
Pacific Rim
SFFD A2 and Tac 7 were very active today around an incident at the GGB.
rustyhodge
I like to listen
San Francisco
So far not hearing anything on 700mhz, just the 800mhz side. (Just adding a data point)
Mostly stuff I'm hearing on digital is SFFD A3 dispatch and some medic unit acknowledgements. EMS4 seems to be mostly ambulances.
Public Works is active too, mostly "going to lunch" and "heading back to yard" type stuff.
KD6JEK
San Francisco
How so? Is it garbled or broken up? Was it easy to program the new system?
officer_415
SF Bay Area
I’m curious if there will be simulcast issues
Seems to be fine so far. I have a big problem with simulcast distortion on EBRCS, but not with SF P25.
All the FDMA (D) talkgroups in the database have been on 700 MHz, and all the TDMA (T) talkgroups so far have been on 800 MHz.
How will those manifest themselves audio wise with digital? Garbled digital or just no audio at all?
Both.
KD6JEK
San Francisco
Both.
What kind of scanner are you using?
rustyhodge
I like to listen
San Francisco
No, just the general digital compression sound that reminds me of using old Sprint phones or Nextel radios. My brain is not a fan of low-bitrate digital codecs.
nokoa3116
Does anybody know if the unencrypted initial dispatch and disposition transmissions will be done on the P25 system or on the current/old Type 2?
N6ML
That's good to know. I was actually looking at that one if it doesn't have any simulcast issues. I don't feel like breaking the bank and getting the SDS-100 if I don't have to.
All commonly-available scanners except the SDS100/200 are susceptible to simulcast distortion (Unication G-series digital voice pagers are also "immune"). It all depends on your location relative to the transmitters. If you're in a spot where the signal from one transmitter is very strong relative to the others, you may do just fine with a traditional scanner. If you move around, you'll likely have good experience in some areas, and bad experience in others.
