XTL/XTS5000 Scan pause
WX9EMT
Backwater Medic
Frozen tundra
I am trying to figure out how pause a scan or lengthen the dwell time on a channel after transmitting. I don't have the ability for the "HUB suspends scan" to work as it is something with the mic I have that doesn't work. So when it is off hook it continues to scan. What I am trying to do instead of buying a new mic or turning scan off is to set how long the radio sits on the transmitted on channel before resuming scan.
For example; if I have the radio on FIREGROUND while the scan is on and then transmit on FIREGROUND, instead of the scan resuming immediately after the tx is done, have it sit on FIREGROUND for like 30 seconds or 60 seconds. Is this possible? Basically mimicing the "HUB suspends scan". I hope I am making sense.
Tech21
Scan Config -->Radio Wide--> Voice Rx Tx hold time is your only option and like GTR8000 said, it probably won't work.
Is your mic clip properly grounded?
GTR8000
NY/NJ Database Guy
BEE00
Voice Rx TX hold time only affects how long the radio dwells on the landed channel once the carrier drops. Setting that to 30+ seconds so that it holds on the channel you just transmitted on might work, however at that point you may as well just disable scan, since the radio is going to wait 30 seconds on every other channel it stops on during the course of normal receiving. Utterly pointless.
BMDaug
I am licensed…
Central Colorado, USA
I’m a Harris guy so pardon my Mignorance, but is there no “scan after PTT” option? You could just have scan turn off after you TX, and manually resume scan when you are finished with the conversation.
-B
WX9EMT
Backwater Medic
Frozen tundra
I have the HMN4079C which I bought to replace my standard mic. The hub suspends scan works with the standard old mic but not with this new mic. The hub is grounded and exibits the same behavior on other radios. I got the mic replaced and the issue persists. That's why I was wondering I could mimic it.
Bummer. Guess I will have to continue disabling the scan like I had been.
a417
Does the XTL have the car radio mute option like the MCS2Ks did?
If they do I can think of a terrible hack to almost maybe kinda-help you get what you want...i mean it would be a kludgy as hell mess...
