Scanner Programming
kye994
Hi looking for someone who can fix a programmed BCD996T scanner that was setup for Horry County Fire Rescue and I don't know what I did but it's completely screwed up and not working. Anyone out there who can help? I know nothing about trunking scanners, my tech experience with scanners ended 25 years ago.
dave3825
Suffolk County NY
There are members on here that do that. For a faster response, its best if you export your programming, zip it up and post it here.
Enforcer52
Voice Of The Piney Woods
Lake Livingston, TX
Here is a file for Horry County P25 Simulcast. Not sure how good the BCD996T will work on simulcast but give it a try.
Use Sentinel or ProScan to import it.
  • Horry.txt
Whiskey3JMC
Simulcastylvania, TE
Welcome to the forums! Why not let us know what it is or isn't doing? Expect a degree of simulcast distortion if you're within range of two or more towers on the simulcast. There are multipath mitigation workarounds in the wiki I linked below but they'll work in some cases but not others. Ultimately you'd be much better with an SDS100 or 200 to track systems with simulcast cells
Use Sentinel ...
Sentinel only works for the x36HPs, HomePatrols or SDSx00. OP has a 996T
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I don't know why people keep on recommending Sentinel for scanners that it won't support. Sentinel is for the HP series scanners and above. The OP says he has a 996T which Sentinel won't support. ProScan is a great choice, but ARC996 is another package from BuTel
Mike
kye994
I appreciate the feedback. I have a Mac so from what I’ve seen I need a windows system computer to do anything remote. My friend that programmed it initially did it right from this forum’s files. I get error messages that say “looking for control channel” Display also shows LNK or DAT at times They didn’t show them prior to me trying to “fix” the problem I caused by hitting buttons trying to lockout some birdies.
Enforcer52
Lake Livingston, TX
Either you have locked out the control channels or the scanner is not receiving them, or the freqs that are programmed in are not being used at the current time as a control channel. Where are you in Horry County? The towers pretty well cover the whole county so you shouldn't have problems receiving.
wtp
Port Charlotte FL
squelch should be on 2.
is it scrolling 'ID SEARCH' or 'ID SCAN' ?
is it showing 'ATT' on the screen ?
did you move the radio to a new location ?
GILLIG40
Northwest, Ohio
I’m looking at my BCD996T. Try to unlock all frequencies
Press menu
Scroll to Srch/CloCall Opt
Press Eyes
Scroll to Freq Lockouts
Press Eyes
Srcoll to Unlock All
Press Eyes
Press Hold/Resume 3 times it will start scanning again
This should unlock anything that you may have locked.
Check to see if the “ looking for control channel “ message is gone
kye994
North Myrtle
One bank it says ID search, the other ID scan
Press menu
Press Eyes
Press Eyes
Press Eyes
Thank you. Will try this in a little bit.
  • Like
Reactions: wtp
kye994
Press menu
Press Eyes
Press Eyes
Press Eyes
So far this
North Myrtle
seems to be working. Thanks
