BCD436HP/BCD536HP: Scanner Scan's channels but does not stop
kc1kkc
Connecticut
I have several local fire/police favorites set in my BCD436HP - A very local police station and I am able to pick up cars and dispatch, but the rest of the municipalities I hear nothing and the scanner does not stop on those frequencies at all.
i am located now in 08008, i have all of the long beach municipalities and beach haven municipalities on my favorites (nothing else) - the beach haven police come through fine, but nothing from the long beach police or fire. It can not be that quiet
avoid is off, attenuation is off, i have the newest firmware - just to make sure the unit is working i started scanning marine band 69 and used a marine vhf transmitter to transmit a radio check, the BDC436HP stopped the scan, and broadcasted my radio check without fail. I also erased the unit, reset it, and tried the same thing by using the full data base scan against the system held at (NJ ocean) the department (long beach) - bupkus
Any suggestions would be very appreciated.
Andy - KC1KKC
u2brent
OAMPT
KRWDPAXKRS1
ofd8001
Louisville, KY
If you are really stumped, try determining which is the appropriate National Weather Service frequency for your area. Then program it in to see if the scanner stops on that. If nothing else, it confirms the scanner is working and you have some kind of programming hiccup going on.
Also, try scanning full database rather than favorites, again more to see that scanner is working.
kc1kkc
Connecticut
RR DB says Long Beach PD is DMR and Encrypted. (Quiet radio would be the result)
As for the rest (conventional?) , maybe they moved and are primarily on this system?
Have you tried the P25?
also this system appears to be the old TRS.
i think that is the answer - i monitor the frequency on a Baofeng analog UHF / VHF and i hear the transmission data - but the scanner does not stop - would i be correct in assuming that once they move to DMR and encryption that there is no setting on the BCD436HP that would overcome that - KC1KKC
kc1kkc
Connecticut
i did this experiment another way, i set in a marine VHF frequency and the unit stopped on that when i transmitted using a VHF handheld - the radio is working fine :-(
kc1kkc
Connecticut
so from this database....
453.45000 WPRH590 RMCC 8
TG 7200
SL 1
PD DispPolice Ch. 1 Dispatch Multicast DMRE Law Dispatch
460.30000 KNCK627 RMCC 3
TG 7200
SL 1
PD 1 DispPolice Ch. 1 Dispatch DMRE Law Dispatch
what equipment is needed to listen into that - would an Anytone DMR radio work ?
KevinC
Encryption
I'm everywhere Focker!
453.45000WPRH590RMCC 8
TG 7200
SL 1
PD DispPolice Ch. 1 Dispatch Multicast DMRELaw Dispatch
460.30000KNCK627RMCC 3
TG 7200
SL 1
PD 1 DispPolice Ch. 1 Dispatch DMRELaw Dispatch
If it's truly encrypted you would need to know the encryption algorithm and key to decode it...and that would be against federal law to do.
darkness975
Latrodectus
TG 7200
SL 1
TG 7200
SL 1
There is no way to listen to encrypted signals on a commercially available scanner. Unfortunately you are out of luck.
jonwienke
More Info Coming Soon!
VA
Not just scanners, any radio. If you don't have the encryption key, you are out of luck.
wtp
Port Charlotte FL
budd, i know that .
but he posted that he could hear his very local tower and cars, and his marine radio.
so on higher power levels he can hear them and the farther away signals he does not get.
so i would guess squelch.
Whiskey3JMC
RTFF
Southeast PA 🇺🇸
Ocean County P25 Phase-II is a simulcast system. Unrelated, encrypted DMR UHF channels aside, the OP might not have the best of luck monitoring the Phase-II system optimally using a 436HP due to potential simulcast distortion issues. All law enforcement (if they've moved over to the new TRS by now) are designated "TE" meaning TDMA-encrypted & no non-affiliate radio can monitor those talkgroups. Fire, EMS, EMA, PW, etc and two sheriff TGs are reported to be in the clear
