Scanner Stopped working
bnails1962
Memphis, Tn
On my scanner, it says, "Finding CTRL Channel"
Can someone tell me what this means? My scaaner stopped working, I reloaded it with my frequencies and still says the same thing.
What scanner is it, all scanners are different, did you make any changes to it? It is possible the control channel changed, do you have all the alternate control channels programmed?
You also should tell us what system this is so we can see if changes were made to the system.
trentbob
Silent Key W3BUX
Bucks County, PA
And what scanner brand would that be? Give us as much detail on your radio as possible, antenna also. What are you trying to hear in Memphis Tennessee?
trentbob
Silent Key W3BUX
Bucks County, PA
Another identical simultaneous post LOL. Perhaps the original poster accidentally attenuated the signal.
bnails1962
Memphis, Tn
Bearcat BCD325P2 Scanner
fxdscon
¯\_(ツ)_/¯
Trunking Scanner Supposed to pick up P25 Phase 2. I dont know much else about it. Its a digital scanner
You need to tell us EXACTLY what systems and agencies you are trying to monitor in Memphis Tn . Post a link to them in the database so that we can see what you are talking about.
62Truck
Ordinary Subscriber
Ø
Still didn't mention my other questions, it's hard to respond if you don't give us all the info we ask for.
A Bearcat BCD325P2. Was picking up Memphis Tn
The info is all right there..
@bnails1962 when did your scanner stop working? From looking at the database it looks like Memphis and Shelby county recently switched from a Type II system to a Phase 2 P25 system
trentbob
Silent Key W3BUX
Bucks County, PA
Does the antenna wiggle at all oh, does it feel loose? Did you accidentally put the attenuator on by mistake, do you see ATT on the display?
I'm still having problems navigating the new database but it appears as if you are in Shelby County which appears to be in flux from a type ll smartzone system converting to a phase ll system.
Without more specific information I would just say what RaleighGuy said. Make sure you have all control channels programmed in case the control channel changed. Tell us specifically what system you are listening to and is it a type ll smartzone system or the new Phase ll system?
62Truck
Ordinary Subscriber
Ø
Even though the database doesn't mention it, the system could be simulcast. The BCD325P2 does not handle simulcast very well.
bnails1962
Memphis, Tn
Phase II system
bnails1962
Memphis, Tn
Antena is fine, Don't know what an attenuator is, sorry
The info wasn't all there, did he program in just the listed CC or the alts too? There could have been a CC change. Also to say he was listening to Memphis, there are 3 TRS in Memphis, not counting Shelby County that also has some Memphis on it. But apparently I don't know how to trouble shoot without asking too many questions, sorry for trying to get all the info.
bnails1962
Memphis, Tn
Im sorry Im not up to date on scanners.
