Here's my question with a pro 197 scanner can you scan a trunk 800 system and also have a have a low band frequency *scanning both at the same time ?
I'm not aware of any trunking scanner that will not do both. What is the make and model of your older scanner?My older scanner will not do it, wondering about this one.
The 1st Trunktrackers (BC235xlt, BC895xlt) could only "trunk" or follow one analog Motorola trunked system at a time or scan conventional channels but not both at the same time.I'm not aware of any trunking scanner that will not do both. What is the make and model of your older scanner?
Thank you. I have a customer that wants to listen to our 800 Motorola trunked system, and monitor the local airport, which is low band.YEs, you may listen to any band the scanner covers all together
