Scanning P25 Phase 2
W2PSK
South River, NJ
Hello. The volunteer rescue squad that I am a member of wants to purchase 3 scanners to monitor three specific P25 phase 2 system talkgroups. Each would monitor only 1 talkgroup. At home I have the BCD996P2 which obviously do the trick, but for only monitoring 1 talkgroup, it seems overkill. Is there another desktop scanner from any manufacturer that costs less than that scanner and can still do the P25 Phase 2 monitoring or do we just bite the bullet and buy 3 of those scanners?
Check this list
W2PSK
South River, NJ
Lots of out of production and handheld scanners in that list. I don't see any alternative to the BCD996P2 in that list that is still in production.
There are only a few still in production, a used scanner works, as does a handheld. But as you wish, it's your parade not mine.
Whiskey3JMC
Resident Numbskull
Simulcastylvania, TE
"Alternative" how? The SDS200 is still in production...
As far as desktop scanners go, not really. How much is your rescue squad willing to pay? RTL-SDR dongles are really the only viable option for Phase-II trunking if you want something currently in production cheaper than a 996p2. Drawback is you'll need a computer and software to drive them
W2PSK
South River, NJ
The SDS200 is obviously much more expensive than the BCD996P2 so it's not a consideration.
I'm not sure a dongle is what they want to use because that would require a computer to run and they want stand along scanners. I don't have the budget for it. I just figured instead of paying around $340 per scanner to monitor 1 talk group, there might be a cheaper alternative without so many bells and whistles to accomplish that.
We might go with 1 BCD996P2 at first and monitor the three talkgroups on scan to see how it works first.
They aren't looking for a handheld scanner, as it'll be on 24/7. They also aren't looking to buy used scanners.
KC1UA
Scan New England Janitor/Maintenance
Hate to be "that guy", but if I'm doing my sleuthing correctly are you referring to the Middlesex County/Sayreville system?
If so that is a simulcast system and could as such be a problem for the BCD996P2 in any case. Any simulcast system will potentially cause that scanner grief.
If not, I'll just shut my yap! :cool:
W2PSK
South River, NJ
No, I am not referring to the Middlesex County/Sayreville system. It's the NJICS system.
KC1UA
Okay. Many, but not all, tower sites on NJICS are also simulcast. Just trying to help; this is a well documented issue, and if they are being bought for professional purposes, it is something that likely needs to be taken into consideration.
W2PSK
South River, NJ
I can monitor NJICS with no issues from home, which is just a few miles from the rescue squad where I volunteer at so it won't be an issue to receive it.
KC1UA
Sometimes a few miles can make a world of difference. Easy solution would be for the OP to take his BCD996P2 to the actual location they're going to be used, put it on the actual antenna (if there is one) they're going to be used with, and see what happens.
That's el cheapo insurance for what could otherwise be a problemo!
