rafale01010
Whats the difference? They both look like the same thing except that Scantenna is $20 more. Is it better to go with that or with the cheaper one?
hoser147 said:Just dont forget to reinforce the antenna..........
W4CRT said:Where do you find the reinforcement documentation?
You learned that one well:lol:btritch said:
hoser147 said:You learned that one well:lol:
stevolene said:I cant hardly read the the diagram or the print on the wiki page for the scantenna reinforcement, also I believe they are using the fiberglass bicycle flag poles? if thats correct all the ones Ive found are solid
stevolene said:ahh haa!!!! (lightbulb coming on) all this time I thought you guys were talking about hollow fiberglass poles and running the antenna through them............tell me something , If I get some aluminum mast, sink about 4 ft of it in the ground, brace it to the eave of the house, will I still need to run a ground wire down the mast into a copper rod in the ground? or would the mast actually be the ground? and if a ground is needed, where do you attach the ground wire at the antenna?
