Scratchy feed
It sound like the input level on your computer is set way to high. Are you using the line in or the mic in?
What level is your radio set at?
mjbjr
Macon,Ga USA
Input level,as in the actual sound from the pc?
Im using the mic on the back of the pc,i just double checked to make sure.
The volume icon on the pc was all the way up,i turned it to half way and still scratchy.
What OS are you running. Windows XP, Vista or windows 7.
Is this a dedicated pc for the feed? and is the radio a dedicated radio for your feed? I would lower the recording setting on the PC for the MIC input to about 25% and have the radio at about 40% of full volume. Don't lower the radio to find the sweet spot. Lower the mic input and shut of the MIC BOOST if it is enabled.
mjbjr
Macon,Ga USA
Running windows 7
No its not a dedicated pc
"is the radio a dedicated radio for your feed?" Not sure what you mean
Ive lowered the volumes and still doesnt change.The feed was doing great all day yesterday and I didnt change anything overnight.
If you want i can remote into your desktop using teamviewer (have helped a lot of people on here) and check your settings and should be able to sort everything out.
If you are ok with it download teamviewer here
TeamViewer - Free Remote Access and Remote Desktop Sharing over the Internet
click the green button and install it.
PM the login and password and i will remote in and fix it,
Let me know
Mike
mjbjr
Macon,Ga USA
Well it seems to have been fixed now.I assume it was the volume issue.I usually have a dedicated pc for it,but the old IDE hard drive has crashed.So I gotta figure what to do with it.I appreciate your help,,and advice.I have teamviewer,its a great program!
Thanks again for your help,I do appreciate it.
Mike
