SDR# SDR# not showing signal
PDXh0b0
Woodland, WA
Remove all the sdr's, only plug in the blog v4
You need to run zadig specifically for the blog v4(only needs to be done once per pc)
your task bar, devices, should show Blog V4
ithetwitch
Rockingham, VA
Did you use Zadig to replace the drivers for your RTL-SDR devices. If so, what does Zadig report as your current driver. Should be WinUSB.
If you tune to a known active control channel, what does it show?
this is what I get when I ran Zadig. All 3 of them are on this version.
PDXh0b0
Woodland, WA
Did you rename the blogv4 at some point?
If you download this
rtl-sdr-64bit-20250126.zip
(With only the blogv4 plugged in)
Extract it, open the folder, type cmd in the file explorer address area, press enter, in the cmd window type
rtl_eeprom
What's the output?
ithetwitch
Rockingham, VA
rtl_eeprom
What's the output?
I did rename it bc I was getting confused on which one was which on my hub.
PDXh0b0
Woodland, WA
maus92
OCMD
You can change the Friendly Name - that should not cause problems. Something like this procedure:
ithetwitch
Rockingham, VA
yeah changing the product back kept the friendly name in device manager.
PDXh0b0
Woodland, WA
Honestly.. renaming it fixed this whole issue for me. I can see signals now in SDR#. Thanks for the assist. I never thought changing the product name would cause this much issue for me.
I remembered reading it at some point, it was on the rtl-sdr site for the blogv4 (at the very bottom 😀)
