SDR Trunk and conventional p25
kyscan23
You should set the PPM to the value you had previously (-1.009) or just -1.1 as indicated, then uncheck the "Enable decoders to auto adjust PPM"
Tried your suggestion and made no change in the issue. I tried another conventional p25 frequency with this same setup and that one decodes without issue.
dave3825
Suffolk County NY
The first p25 channel is a half mile from you. How far is the second one you tried that decodes without issue?
