SDRplay - DSDplus Question
wa2sqq
Bergen County, NJ USA
I'm using an SDRplay together with SDRuno. I'm also using DSDplus to decode digital modes. I'm finding that it can't decode DMR. I was told that SDRplay can't provide the I&Q channels using virtual audio cable software - supposedly a custom DLL file needs to be created.
DSDplus works just fine if I feed audio frm a conventional receivers discriminator tap.
Is anyone able to decode DMR using this equipment? Any suggestions?
slicerwizard
Toronto, Ontario
DSD+ doesn't use I/Q data, so I don't see how that's relevant.
Then it should work fine if you feed it flat FM demodulated audio, so turn off de-emphasis and any other audio filtering.
brettbolt
Yes, I am using an SDRPlay with DSDPlus and can confirm it works.
Here is how I set it up:
1) Get SDR# and the RSP1 SDR# Plugin from sdrplay.com
2) Turn off 'Filter Audio' in SDR#. (It is 'on' by default so you need to do this).
3) Install 'VB-Cable'.
4) In SDR#, set it to output to VB-Cable.
5) In DSDPlus use the command line argument to get it to take the output from VB-Cable. On my computer, I use the following command 'dsdplus -o2'. (If you run dsdplus without any arguments it will give you the device numbers, and VB-Cable may be something other than 2 on your system).
Hope you get it working too.
Brett
N6BY
D
DaveNF2G
Guest
The problem is not necessarily the SDRPlay. The Uno software might not be configured to route the correct signals to external software.
bheisner
Silver Spring, MD
Brett
N6BY
I finally managed to get DSD+ 1.101 to decode DMR with SDR Console 2.4 build 2760 and Virtual Audio Cable 4.14.
The key settings in SDR Console were:
Select the Audio drop down in the VFOA panel
set Playback Drive to Line 1 (Virtual Audio Cable)
Select the FM drop down in the DSP Options panel
set FM to FM Wide, Data (No filters, No de-emphasis)
DSD Plus is decoding fine now, however I'm able to hear any audio on my laptop speakers.
I'm also not getting an audio file written out, even though I specified on with the -O option.
These are the parameter that I specified at startup:
DSDPlus -i5 -o1 -E -O DMR.wav
DSD+ 1.101pt
Adding NAC/RAN/DCC/RAS data to event log file entries
Appending synthesized audio to file 'DMR.wav'
0 frequency records loaded
0 radio records loaded
0 group records loaded
0 site records loaded
0 network records loaded
audio input device #1 = 'Integrated Microphone Array (2-'
audio input device #2 = 'Rec. Playback (2- IDT High Defi'
audio input device #3 = 'Microphone (2- IDT High Definit'
audio input device #4 = 'Line In (2- IDT High Definition'
audio input device #5 = 'Line 1 (Virtual Audio Cable)'
audio output device #1 = 'Speakers / HP (2- IDT High Defi'
audio output device #2 = 'Line 1 (Virtual Audio Cable)'
audio input device #5 (Line 1 (Virtual Audio Cable)) initialized
audio output device #1 (Speakers / HP (2- IDT High Defi) initialized
D-STAR decoding enabled
NXDN4800 decoding enabled
NXDN9600 decoding enabled
DMR/MotoTRBO decoding enabled
P25 Phase 1 decoding enabled
X2-TDMA decoding enabled
ProVoice decoding enabled
NYG
Have you turned off de-emphasis in SDRuno?
If not, in the receiver control click EXW and click DEEM so it isn't highlighted.
bheisner
Silver Spring, MD
I managed to get the audio working. I was monitoring a DMR channel that didn't have much activity
I just tuned to a P25 Phase 1 frequency on the Montgomery Country TRS here and I'm hearing decoded P25 audio through my speakers using with DSD+.
br0adband
Springfield MO
Also ensure that you have the Windows audio mixer for the VB-Cable set so it's 16 bit 48 kHz as DSD+ requires that for input purposes - by default Windows tends to assign mixer inputs at 16 bit 44.1 kHz and that can make a difference and prevent successful decodes.
bheisner
Silver Spring, MD
Just a FYI. The default version 4.14 seems to be 48 kHz now.
