sdrsharp not working
lord-sadler
hello everyone,
my laptop (running windows 7) recognize sdr dongle as keyboard, sdrsharp not showing it on device settings, i installed the drivers using zadig and did everything right, but when i click on the play button in sdrsharp it says "device not found".
can any one tell me how to get it working.
thanks,,,
mattwillson
Did you run "install-rtlsdr.bat" in the sdrsharp folder? When running Zadig, under options did you check "List All Devices" and uncheck "Ignore Hubs or Composite Parents"?
lord-sadler
thanks for your reply, yes i did all of that but didn't work.
mattwillson
In SDR# under Source, is RTL-SDR (USB) showing up as an option? When you click the gear icon is the dongle available in the device list?
lord-sadler
is RTL-SDR (USB) showing up as an option? Yes it there.
When you click the gear icon is the dongle available in the device list? No, it's not.
mattwillson
Got me stumped, have you been right clicking Zadig and running as Administrator?
morfis
Though you have said you installed the drivers correctly the above suggests you didn't.
Re-install the drivers being careful to apply them to the correct Intereface/device.
lord-sadler
thanks for all of you, i really appreciate your help, i did reinstall the drivers but this time (bulk in interface 0) not showing, instead i found RTL2838UHIDIR, I did everything as you said but didn't work.
rabbit108
S.E. VA
I tried the dongle with the latest SDR# software. I used my Windows 10 computer because my old Windows 7 computer was acting up. I couldn't get v1807 to work either at first, but finally did. Maybe this will help:
reinstalled driver
unplugged dongle and then reinserted it; heard normal USB sounds
checked Device Manager
selected dongle as source
It works!
lord-sadler
thanks for all of you, it finally worked!
i deleted the drivers from device manager, reinstall it, and unplugged the dongle and replugged it again and when i opened SDR# i found the device in the gear settings icon.
rabbit108
S.E. VA
Thanlk you for the report with the good news! Glad we were able to help.
