Ubbe
Scanners almost always benefit from using external filters and SDS scanners very much so as their receiver are very poor.it says if I use the Normal or Invent for global/site. I'll need some sort of external high/low pass filter.
There are always internal filters in a scanner. First there are bandfilters at the antenna port that let trough a wide band that might be the whole VHF-Hi of 137-175MHz. Then the input signal are mixed with the oscillator signal to produce a third frequency that are followed by a more narrow filter of maybe 10MHz.
That 10MHz where too wide to be used in a SDS scanner but a more suitable narrow one of perhaps 1MHz would be too expensive to Uniden to be used. Instead they added the filter settings that use the 10MHz filter but can push it to either side so that in a normal scanner it is centered at -5MHz and +5MHz but the filter settings in a SDS scanner can make it go up to -1MHz and +9MHz or down to -9MHz and +1MHz.
It's the same filter but its frequency range gets moved and if there where an interfering signal at -2MHz when the filter where set at +/-5MHz it can then be blocked by moving the filter to -1MHz/+9MHz and the receiver will then work much better. But it could instead receive an interference that are at +8MHz that didn't affect reception using the +/-5MHz setting. So you will never know what type, and even if, a different filter setting will help.
The +/-5MHz filter are called Off and Normal are -1MHz/+9MHz and Invert are -9MHz/+1MHz and Wide are half of Normal/Invert to make it -2.5MHz/+7.5MHz and -7.5MHz/+2.5MHz
/Ubbe
