sds 200 help
FireMedic658
Hey all! I just got my sds200 and I love it. However, I'm having an issue with the federal database showing up on my scanner Also, I have everything checked in the "service types;"
But, this is what my scanner shows under "select lists to monitor;"
7147BA64-8B61-4FB0-BCF4-666A49E7017B.jpg CA9A989D-8E04-44D0-A5FD-165CFDA7630B.jpg
As you can see, there is no Federal, oakland or ogemaw on my scanner.
Issue number 2) In my Macomb county profile, I have 50MASH as my priority channel. however, when I turn the unit on, it says, "no priority." what am I doing wrong?
hiegtx
Mentor
Dallas, TX
View attachment 108291 View attachment 108292
If you have those created as Favorites in Sentinel, but are not seeing them in the scanner when trying to select lists to monitor, they are not being downloaded to the scanner. In your Sentinel Profile, make sure that each of those lists are set to Download to the scanner. If you want then 'on' (being scanned by default), then set them also to be monitored.
The Priority setting for the scanner, in your Profile, is for use with Conventional channels, not trunked systems. Your 50MASH channel is on your statewide trunked system. MPSCS.
You can set it using Trunking Priority, but that involves several steps.
Append the system to a Favorites list (sounds like you already have done that).
Make sure that you have the correct site(s) for your area selected for your statewide system.
Tag the talkgroup as Priority using the Favorites List Editor.
Next, in the Favorites List editor, click on the Options tab for the MPSCS system.
Enable Priority ID Scan on that specific trunked system.
Trunking priority works differently than conventional. For conventional channels, the scanner will periodically check to see if any of your designated (conventional) priority channels are active. If so, it will jump to that frequency.
On the other hand, Trunking Priority will only check to see if one of your talkgroups, designated as Priority, is active, when the scanner is scanning that specific system. If it is in the middle of a different trunked system, or scanning conventional channels, it will not switch back to your talkgroup tagged for priority.
See this thread for further discussion. Many people have posted mixed results on how well trunk priority worked (or did not work) for them.
But the "no priority" error message you got only applies to conventional channels, Turning that function on or off (which does show as 'Pri' in the display when enabled) does not affect trunked system priority. For that, you have to manually turn it on or off by editing the system. It cannot be directly accessed via the keyboard.
dave3825
Suffolk County NY
Macomb County Michigan does not seem to list anything federal in the database on radio reference. Are you speaking of the federal stuff in the Nationwide frequencies seen in the second pic?
hiegtx
Mentor
Dallas, TX
I think the OP was actually referring to the the issue that he had created a "Federal" favorites list in Sentinel (shown in his first screenshot), but it. along with two other favorites lists that show in the screenshot from Sentinel, is not available in the scanner (screenshots of Select Lists to Monitor). While you may be correct that there is little federal activity in that county, his list does not show in the scanner as an option. As I noted, it sounds like he did not select it to be downloaded to the scanner.
