SDS Discone help
raf1919
Hi All, Long time lurker first post... total noob here.
I have a SDS100 and felt like tinkering to see what Antenna upgrade would bring in, from reading on here seems like another duck is waste of time and discone would be better. Going to get a D130JN or D3000N (still deciding) attic mount, but I need help with the cabling and connection to make it work. Going to use 25ft LMR400UFUMUM25 but what do i need to make the connection to the SDS100 (SMA)? Is it just a simple N to SMA connector, I've seen mention of using 240. Also if only running 25ft do i Need LMR400 or can I use 240. If no improvement on SDS I can always use this for my ADS as well but want to see what kind of range improvement I'd see.
raf1919
Hi & Welcome to the RR forums. What band(s) are you looking to bring in better?
Honestly I'm just tinkering to see what I can pull in and experiment. I mainly I Listen to my local (chicago area DUCOMM) Central dispatch which is P25 and I get that in pretty good. But the tinker in me wants to see what else I can pull in and eventually maybe use the setup for my ADS Pi system.
Ubbe
Stockholm, Sweden
A pigtail would be the best. It makes it easier to handle the scanner and will not strain its connector with a thinner much more flexible coax. SMA male at one end, preferable an angled one, and the other end to match whatever the bigger coax will use.
If you have the SMA-BNC adapter you could have an angled BNC connector at the coax instead of the SMA one.
Pigtails
/Ubbe
raf1919
Pigtails
/Ubbe
perfect thank you.
iMONITOR
Silent Key
S.E. Michigan
lzielasko
Nashua, NH
Switched from a discone to the OmniX a year ago. Big improvement.
togo54
Paris, Arkansas
I'm using a discone in my attic and running rg6 coax to boot. Why? Because the coax was already there. Not sure what, if anything I might be missing out on but attached is a partial screenshot of some of what I do receive.
jonwienke
More Info Coming Soon!
VA
I use a discone and 20 feet of LMR400 for my scanner reception, and that works pretty well. RG6 means extra loss at each end of the cable due to impedance mismatch, but not a huge amount. I wouldn't buy RG6, but I've used it when I had a bunch lying around, and it worked reasonably well.
darkness975
Latrodectus
Though there are antennas that handle over 700mhz better , discones can still work well depending on your configuration.
togo54
Paris, Arkansas
The RG6 in my house is from past satellite tv installations and and in all 5 locations in my house that the cable it run it is in interior walls. I'll live with a little signal loss as opposed to trying to run new cable :)
jonwienke
VA
That makes sense if the RG6 is already installed.
Ubbe
Stockholm, Sweden
If you use the discone at 400MHz and lower it will probably work fine. At 900MHz its directivity points up at a 60 degree angle and at the horizon the signal are down 10dB or more. But if you only have strong signals then 10dB loss are no problem, or cut all elements down to half size.
/Ubbe
R0am3r
Salt Water Conch
Oneida County, NY
@Ubbe - Just wondering, what discone antenna did you model? I routinely "see" aircraft ADS-B signals from 100 - 125 nm (185 - 232 km) away from me. Because of the aircraft altitude, that certainly isn't a horizontal distance. Based on these distances, it is obvious the antenna isn't limited to seeing signals directly above it. For reference, I use the MP Antenna 08-ANT-0861 discone.
TailGator911
Silent Key/KF4ANC
Fairborn, OH
The Diamond D-130J wideband discone serves me well for all but my local MARCS P25 Phase 1 system, for which I use a Terrawave directional yagi (Scanner Master) aimed at my local site about 5-6 miles away. My discone does very well for vhf/uhf and mil-air. I have both on a mast at the side of my house about 25ft high. I am in a sweet spot here for everything, so the 130J is all I need.
Ubbe
Stockholm, Sweden
You use the "spider" antenna 08-ANT-0861, which could perhaps work as discone but more like a multifrequency GP. I have a 100cm telescope antenna on my desk that catches ADS-B from 100km and doesn't seem too hard to receive signals inside a room.
The diagram comes from Sirio and are for their SD2000 discone.
Discone works well for frequencies up to 400Mhz, incl VHF air and MIL air.
/Ubbe
N9JCQ
Lake Barrington, IL
/Ubbe
I use its little brother for ham and aircraft. Works great!
