Stop it. Pick a thread and stick with it.Is the update 20 bucks or just the waterfall? Or do you have to get it all at the same time as a package? Thanks!![]()
Yeah I realized that it's just another update and not an upgrade per se. I'm looking forward to seeing how things develop, right now everything's working so well, sans encryption.It's very simple, so let's break it down so we don't go back and forth in two threads answering the same questions:
1) The latest version of Sentinel x36HP/SDS (2.05.03) is FREE and you download it here: https://info.uniden.com/twiki/bin/view/UnidenMan4/BCDx36HPSentinel
2) The latest firmware for the SDS100 and SDS200 (1.23.01) is FREE and you download it with the latest version of Sentinel as noted in #1. This firmware includes "improved digital reception performance"
3) The optional new waterfall/spectrum display for the SDS100 and SDS200 costs $20 to unlock, and requires the latest versions of Sentinel and firmware as noted in #1 and #2. You purchase that key from myUniden - Customer Product Registration and Support Area
Of course! You pick, and combine them.Stop it. Pick a thread and stick with it.
There's like 10 cells here on our primary site and it's working fine. I honestly can't really tell any difference as yet -- in terms of audio quality.Yes, my area has one site called simulcast with 26 towers which of course can't be locked out or manipulated in the radio.
There's like 10 cells here on our primary site and it's working fine. I honestly can't really tell any difference as yet.
Is it just me or does the overall scanning speed seem a tad quicker?
Yeah true. I'm not searching -- just scanning on this system -- so perhaps that is where the speed bump lies.It definitely seems to be running a little faster. Maybe that's just because I haven't watched it scan much but it's going through all the programmed TG's quick.
FYI the "cell" is the whole simulcast site itself, so only one of those per unique Site ID. A simulcast cell is comprised of multiple physical transmit/receive locations, known as "subsites", which together act and appear as one single "site". Or in slightly different terms, a simulcast cell is a collection of multiple physical sites within the coverage area, which together make up one "virtual" site. (not picking on you, just explaining some of the terminology so everyone is on the same page)There's like 10 cells here on our primary site
I've noticed that my issues depend on wether my SDS's are receiving Phase 1 or 2, which switching between the two is common in my use case. Also the audio quality issue is very dependent on where I'm at in relation to the sites I'm receiving.Like it said in the release notes, this "improvement" might not be noticed everywhere. From my observations so far, as I noted it has and hasn't. The audio quality has improved from the previous public release, but Phase 2 audio still goes into this garble at times and also have seen it stop scanning, full signal bars, no P25 or LNK indicator. This is across 4 separate SDS200's, 2 different systems, all simulcast since this afternoon's release. Phase 1 has no issues.
I also monitor a Phase 2 single site system and this issue hasn't happened, so this probably has something to do with different control channel data. Like I said, it's almost there, just one more tweak and should be good.
On another note, the P25 OFT (One Frequency Trunk) system has drastically improved. The scanner is stopping on transmissions, unlike before where it skipped a couple cycles and picked up mid conversations.
Cap+ rest channel decoding seems to have slightly improved too. NXDN trunking also seems to have some decoding improvements too.
I'll keep experimenting with different systems, but I'm sure this is why the location disclaimer was added in.
Got it, yeah, I just misspoke there.FYI the "cell" is the whole simulcast site itself, so only one of those per unique Site ID. A simulcast cell is comprised of multiple physical transmit/receive locations, known as "subsites", which together act and appear as one single "site".
Do you have any NXDN OFT you can comment on?NXDN trunking also seems to have some decoding improvements too.
I’m over in Muskegon. I plan to update my 200s this weekend to try it out. Will be curious to see if the change is limited to sites in your area or MPSCS reception in general.Much improved reception on the Oakland County Simulcast here in southeast Michigan. Before the update I wasn't hearing anything, after Loud and Clear!
Doesn't seem to do anything for RF Gain or whatever the improvement was "digital decode"I have a question in regards to the RF gain . For those of us monitoring a system say 50 miles away having the static along with signal . Would this new upgrade help people like me monitoring an analog system that is hard monitoring ? Would it just be louder static ? I’m confused about how all of a sudden how RF gain would be better with an upgrade or worse from the scanners hardware / software . would the upgrade be worth it?
No NXDN OFT's in use around me anymore. I'm not sure what you mean by the P25 RID's being displayed regardless of where they originate from?What they define as a receiving area could be a porta potty in the middle of the desert. Really vague.
I would be happy if it would display all P25 rid's, regardless of where they originate from.
Isn't RF gain only accessable while in the waterfall function and not at all in other modes like when scanning?I have a question in regards to the RF gain .
