SDS100 Battery
simswolf
Southbury, CT
Has anyone had problems with the BPS100 (Model BT-954) falling or coming apart? I have two that have pulled apart at bottom. Would it be safe to run a piece of tape around to hold them together? They have not completely separated just some what loose.
buddrousa
Are these the small batteries or the large batteries?
If the Batteries are swelling and coming apart then no I would not trust them.
How old are these batteries as Uniden may replace them?
Eng74
Kern County, CA
I think there was reports of some batteries swelling both small and large batteries over the summer. I want to say Uniden replaced them with new large batteries.
SteveSimpkin
Lancaster, CA
Here is the main thread about swollen batteries discovered on a few SDS100s.
buddrousa
Mine (small battery) was one and it was not replaced it was the 2nd reported battery to a Uniden Rep. It was found after I received my large replacement battery as an early adopter.
simswolf
Southbury, CT
These are the larger batteries. The original that came with scanner now two that were purchased as spares. After a closer look they are not swelling just separating at corner on the same side of contacts but at opposite end where the low end of bottom piece doesn't cover the cell.
