SDS100/SDS200: SDS100 current draw
N0ZQR
Nebraska
What is the total current draw for the SDS100 with the BS-GPSK kit?
Have searched found nothing.
N0ZQR
Nebraska
I read the whole discussion,the only thing I see was the “draw” for the SDS and not the two of them together. I need to know so I can get the right size cigarette lighter adapter to run the combination.. what I am using now gives me the low voltage message.
N0ZQR
Nebraska
522
Murray, Utah
Maybe its your vehicle cig port not providing enough juice. Read up on your vehicle owners manual on the cigarette port you are using, and report back.
radioman2008
Batlabs user Wazzzzzzzzup (2001-Present)
Motorola 800 System 1632 Tampa Bay Florida
I have an SDS100 and a USB port analyzer....
with the SDS100 on, scanning and display active, its pulling from the USB port 0.84A at 4.9V (5V) so its using approximately 4.1 Watts (.84 X 4.9)
for comparison the 436HP draws .19A at 4.9V (5V) (.19 x 4.9) is .931 watts
whenever i run the SDS100 for long periods of time it is always warm to the touch, the 436HP? cool to the touch
so the SDS100 wastes alot more power in heat
iMONITOR
Silent Key
S.E. Michigan
Unlikely. The typical cigarette lighter jack has a 10A fuse, sometimes even higher.
Ubbe
Stockholm, Sweden
It's less than 100mA for the GPS. Check that the ciggplug can deliver 1A or more. If you charge the SDS100 battery at the same time it will be an additional 500mA. I have several ciggplugs and most of them are of bad quality and stops working when temperature reaches the freezing point and one drops power when it heats up after a while of use and one could initially power two dashcams but after a couple of months it could only manage one dashcam.
/Ubbe
