Why is Phoenix such a challenging RF environment? I mean compared to places in the northeast where I would have thought the biggest problems would occur since there are so many systems saturating every public safety band.
And the 436 and G4 where not affected by that interference. Are the SDS100 poorly shielded, as was suggested earlier, or is it the SDR frontend receiver that are not as good as a conventional receiver and cannot handle the different kinds of nearfield interferencies that we all have now with routers, modems, computers, network and USBcabling and all those computer boxes in modern vehicles?
/Ubbe
Not doubting you there. I had some issues originally but firmware updates seem to have solved almost all of them fortunately.
I met with another new SDS100 owner today for lunch in a different location and all of our results, and impressions about the SDS100 being no better than and at times inferior to the 436 were the same. We both agreed that interference was a likely culprit, and that we often see insanely high noise levels. We also both agreed that neither can touch the G4 when it comes to pulling in valley simulcasts other than the one we are sitting in the middle of.
My offer of a steak dinner still stands for anyone who can meet me and show me any scanner that can even come close to picking up the various Phoenix area simulcasts the way the G4 does. They are a world apart in performance for me, and for those who I've been meeting with and talking to in the valley and even other places.
It's baffling. I mean, we are big metro area, maybe like the 8th largest or something now, 3.5 million people, maybe 15-20 simulcasts total, so it's a lot...but it's not as bad as other more densely populated metro areas I'm sure. Myself and others are all wondering the same thing you are wondering. Is there something special about Phoenix in terms of unusually high interference / noise floor? I don't get it either. I don't disbelieve those who have glowing reports on this scanner. I have to believe that some people are thrilled and I am happy for that, but I don't understand the night and day disparity.
Not only should holding on a site not cause fluctuating RSSI, but it should not cause the constant loss / re-capture of signal and repopulation of the various data in detailed mode.
If I use Search and stop on a P25 trunked site CC, it sits there with full signal strength displaying constantly and the NAC revealed and no blinking / loss of any of the information.
If I program a single P25 site in and set ID SEARCH On, i will see the signal "bars" icon show full signal strength for a second along with all of the relevant trunked system information, then it the signal strength shows zero and all relevant trunked information disappears for about half second -- and it repeats this forever and ever. I doubt it's unique to mine and likely what everyone experienced. But it is NOT something that anybody should experience if all you have programmed in is a single site.
If you only have a single site programmed into your whole scanner, you should see the signal strength and all relevant trunked information 100% of the time, at least until it switches to a voice channel -- at which time some information may change but you'd still see signal strength and info.
It's almost what you would expect to see if it were scanning all of the trunked frequencies on that site rather than holding on the control channel. That's not what is happening though, because I only have the control channel programmed in. But it absolutely should not be displaying/dropping data and signal every other second.
Mike
Verizon using the 700 MHz band for their cellular service may also play a part in the high noise floor here. I believe KR7CQ mentioned that even the G4 goes deaf close to their towers. Perhaps the cumulative effect of all of their towers is part of the problem here?
Just a thought.
John
Peoria, AZ
Agreeing with Paul's simple assertion regarding the G4/G5 being RX band specific.
Sounds like at the end of day pulling out your hair you need to return the radio and invest in commerical gear if you want to monitor the PHX area.
Stop messing with consumer grade equipment. Look at what your time is worth at this point. From reading posts back to many of years now that the systems in PHX have always had LSM issues and RF stuff going on. The new radio seems to be working across the board pretty well on other systems except for
Arizona PHX area. Seems like you are going to have to invest a big chunk of change to get your job done right. Consumer grade equipment is not going to be the answer in your area. Its a bummer but o well. You still have alot of stuff in the clear. Its all a give and take situation.
And as I mentioned before, the SDS100 has more shielding than the 436.....
Hello this question goes out to policefreak post #73. You were inquiring about an issue with Burlington County. I also monitor Burlington just wondering do you have the various sites in one favorites list or each site in a separate list, aka West, Northwest etc.? I was wondering what is the best way to handle that. While on that same post what is the difference between hold time and wait time in P25 systems? Thank you for any imput
Yup, agreed. For P25 I will be using Unication, which is professional gear, designed for public safety use. For analog stuff, my scanners and setup do a great job, but not for PS simulcast. Maybe at some point I will start playing around with Motorola radios and doing what goes into making them work on a system.
You are a smart man. The majority of the people that have been thru this frustration and stepped up the game and bought Moto Gear. The cost is higher of course but its another tool that you add to your toolbox. You have your scanner to do certain functions and surrender to its limitations and use your Moto Radio for other systems that require commerical grade equipment. Good Luck
If the squelch method doesn't work or even if it does better but try setting that systems hold time to Max and see it RSSI becomes more stable.
Houk
