So, just got back from testing Uniden's suggestion and sadly, it failed.Uniden's tech support suggested "Please try the following: set multiple favorites for each of the towns and then turn them all on with the GPS function enabled. This allows for the dynamic shift you are looking for with the GPS function."
I will try this over the weekend.
I created multiple favorites for three of the cities I am working with and, with all of them turned on, drove through each of the cities once the scanner found the GPS satellites. The scanner did not change from one city to the other as I expected although the GPS coordinates on the scanner's display showed my correct location. The scanner stayed on my starting city of Overland Park the entire time. I power cycled the scanner while in a different city (Lenexa) and once the scanner found the GPS satellites, it switched to the Lenexa favorite. However, when I
drove back to Overland Park, the scanner remained on the Lenexa favorite.
I reached back out to Uniden and am awaiting further guidance from them.
