Now attached to SDS100FirmwareUpdates < UnidenMan4 < TWiki
This thread would seem to be an obvious candidate...
interesting
Note that the protocol is released without official support. I've never used the protocol for anything other than very basic things in hyperterm mode. That said, community support can be helpful.
So then it is not really 'protocol'. Look up the definition of protocol. If it is not official, then it is not protocol.
It is an official Uniden company internal protocol that Uniden has graciously shared with the public, has but without support.So then it is not really 'protocol'. Look up the definition of protocol. If it is not official, then it is not protocol.
Yes, I believe that was the intention.W4ELL and Steve,
OK, but I am still lost as to how an official document cannot be supported just by the very definition of a protocol. Are you saying it is just not supported here or outside of Uniden (that is, they will not respond to comments)? That I can certainly understand, but it was not made clear.
Upman, will this update fix the many missed Transmissions on the Bucks County P2 simulcast system?
www.dictionary.com said:(noun) a set of rules governing the format of messages that are exchanged between computers.
Starting BCDx36HP Command Sieve, 3-character commands ranging from [A] to [Z]
(9 case variations/command)
Scanner Under Test: SDS100 (ESN 383260880*****, Firmware Version: Version 1.03.01)
Active Commands not listed in the "SDS100 (UB383Z) Remote Command Specification
Version 0.01 2018/04/13."
Note that "active" is not the same as "useful", and that just because you
CAN do something doesn't mean you SHOULD...
use these carefully and cautiously and at your own risk!
ALV
AUF
cdb
cdc
cds
cli
crg
DIR
DLC
ESN Get Scanner's ESN (ESN,383260880*****,107,1<0D>)
esn Get Scanner's ESN (esn,383260880*****<0D>)
FPR
FRX Receive File?
FTX Transmit File?
GLG GLG,0156.2100,FM,0,97,Santa Clara,Santa Clara County - Sheriff,Primary,0,1,,,NONE<0D>
MSM Puts SDS100 in Mass-Storage Mode
pas
PRG "Remote Mode" / "Keypad Lock"
PWR
QKS
RBS
rbt
RBW
rdc 04602750, 04602750,FIR2=20989, Noise=28318, DA=320,595, 4240854
RMT RMT<09>ERR<09>494<0D>
sdc NO RETURN DATA -- interface "goes deaf" after this command
SDR Enters SDR demo/placehold visualisation
SQL Get/Set Squelch
SQV
SSC
SUS NO RETURN DATA
TST
UDP
UHC
VOL Get/Set Volume
WIN WIN,36,04602750
